camshaft pulley and distributor don't line up ???
Old Nov 25, 2005 | 09:31 PM
huey's Avatar
Default camshaft pulley and distributor don't line up ???
i have a 1994 honda civic dx and i had to replace the head. i purchased one from american cylinder heads with the cam and when i put the cam shaft pulley on it is set to the "up" position and now my rotor button points to the number 3 plug. why is this? it should be pointing to the number 1 plug by the way the head is not on the block yet. it is a 16 valve head single cam my old casting numbers on my old head were pm9-2 and on the new head they are pm9-3
Old Nov 26, 2005 | 09:52 AM
95DxSi-R2
Guest
Posts: n/a
Default Re: camshaft pulley and distributor don't line up ??? (huey)
bump
Old Nov 26, 2005 | 11:26 AM
del_slow420's Avatar
Default Re: camshaft pulley and distributor don't line up ??? (95DxSi-R2)
would that be because it is on the exhaust stroke not the intake stroke...
Old Nov 26, 2005 | 11:54 AM
95DxSi-R2
Guest
Posts: n/a
Default Re: camshaft pulley and distributor don't line up ??? (del_slow420)
but it lines up only one way right?
Old Nov 26, 2005 | 11:57 AM
anony95ex's Avatar
Sounds like you have the distributor installed 90 degrees out. Try removing it from the head, lining the rotor up with #1, and then reinstalling it while keeping the cam drive gear in the "stright-up" position...
Old Nov 27, 2005 | 04:41 AM
huey's Avatar
well i finished installing the head and got to the portion where you put the valve cover on and bingo!The two holes in the front of the valve cover where a stud would be to put a nut and the ground wire are cam cap bolts so i guess the part store screwed up and sent me the wrong head.(nowhere to bolt the valve cover to and the timing off should have gave me a hint. but the obvious wasn't so. where i am going with this is that i guess a pm9-3 head and a pm9-2 head are not interchangeable) if anyone knows diffrent please let me know because i really don't want to take this head off if i don't have to. i have till monday before i can order another so please let me know.also i am new with honda's my wife drives a 89 crx si and i just bought this 94 civic and i am not having too much fun with this.to the reply of the guy who said turn the distributor 180 degrees i tried that already with no results distributor will only go one way.
$amGD3
11
Apr 16, 2018 07:54 AM
vtechjunkie
Jun 17, 2010 06:51 AM
jdmlife
May 28, 2004 06:47 AM
Layziebtnh055
May 15, 2004 07:36 AM
RTW DC2R
Jan 30, 2004 06:15 PM
