First Turbo Collector (for me)
Old Nov 25, 2005 | 10:40 AM
91TSiGuy's Avatar
Default First Turbo Collector (for me)
Here's some pics of my first turbo collector. (although it was my second attempt) I had to make a few changes to my jigs, but now these should be easily reproduceable for me later on.
Cutting was done with a 6.5" x 10" Grizzly bandsaw with bi-metal blade.
Welding was done with a Lincoln PT185, 1/16" 2% tungsten, 125amps, 25cfm gasflow with a #8 cup on a gas lens. Piping is sch10.
I plan on going over the welds again with 3/32" tungsten and back purging once the rest of the manifold I'm making is farther along. The edge was lightly beveled on a sander, but I plan to take it farther with the next collector I do. I will also clean up the inside of the collector once the manifold is done as well. I left it as is for the pics to show the actual fitment.
Old Nov 25, 2005 | 11:34 AM
Jays91DXhatch's Avatar
Looks nice but why is there no prenetration on the inside?
Old Nov 25, 2005 | 11:42 AM
Hybrid_Coupe's Avatar
Default Re: (Jays91DXhatch)
it looks to have penetrated to me...you can see the discoloration....But why didnt you weld it on the inside?
Old Nov 25, 2005 | 11:45 AM
Bailhatch's Avatar
Default Re: (Hybrid_Coupe)
nice fit up for one of your first ones. Looks like your saw cuts straight too
Old Nov 25, 2005 | 12:08 PM
aspec101's Avatar
Default Re: (Bailhatch)
just because it is discolored does not mean it has been penetrated.
Old Nov 25, 2005 | 12:20 PM
k24em2's Avatar
Default Re: (aspec101)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aspec101 &raquo;</TD></TR><TR><TD CLASS="quote">just because it is discolored does not mean it has been penetrated. </TD></TR></TABLE>
Hahahaha. This could get dirty really fast.
Looks good though. It's tough to weld down inside the middle of it.
Old Nov 25, 2005 | 02:36 PM
91TSiGuy's Avatar
For the penetration questions, there's two reasons for that. One, I should have been using a thicker tungsten and didn't feel comfortable with as many as many amps I was running through the 1/16 tungsten. It may have been fine, but I just had that thought in the back of my head thinking I heard/read it somewhere.
The second reason is I wasn't backpurging the collector at the time. I'd rather have only a tiny amount of crystalization on it than a lot. I also plan on going back over it (as mentioned above) with more heat and back purging so I can get fuller penetration. I don't want all that contaminated metal being sucked back up into the puddle later.
Old Nov 25, 2005 | 03:29 PM
ccfab's Avatar
Default Re: (91TSiGuy)
how did you prep your metal
Old Nov 25, 2005 | 04:37 PM
PSI2HI's Avatar
Former Vendor
Looks good man.
Old Nov 25, 2005 | 08:00 PM
TurboPinto's Avatar
Default Re: First Turbo Collector (91TSiGuy)
Looks good. I wouldn't worry about the amperage. I run 150amps through a 1/16 tungsten on a daily basis.
Best regards,
Tony Reiners
Old Nov 25, 2005 | 09:23 PM
TIGboy's Avatar
Default Re: First Turbo Collector (TurboPinto)
looks awsome, ill be starting mine and I doubt it will come out that good, very nice
Old Nov 25, 2005 | 09:26 PM
Race Egr's Avatar
Default Re: First Turbo Collector (JDMEG84dr)
Im kinda new but would u normally weld it on the inside to?
Old Nov 25, 2005 | 09:38 PM
RCautoworks's Avatar
Default Re: First Turbo Collector (super-NAPIER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by super-NAPIER &raquo;</TD></TR><TR><TD CLASS="quote">Im kinda new but would u normally weld it on the inside to?</TD></TR></TABLE>
If you get good enough penetration, there is no need to.
Old Nov 25, 2005 | 11:27 PM
.RTErnie's Avatar
Default Re: First Turbo Collector (90blackcrx)
if you purge the inside and weld it with one pass...you'll find that you will loose the "sharpness" of the collector. I'd rather weld it in two passes. One outside like he did and then one inside.(with much less heat)
Old Nov 26, 2005 | 07:42 AM
91TSiGuy's Avatar
Default Re: (ccfab)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccfab &raquo;</TD></TR><TR><TD CLASS="quote">how did you prep your metal</TD></TR></TABLE>
After cutting on the bandsaw, I did take the inner edge faces to a 12" disc sander to smooth them out a little more. Then I sprayed them down with 2+2 carb cleaner to get most of the cutting fluid out, and wiped them down in a final pass with acetone.
Old Nov 27, 2005 | 02:09 PM
preveink's Avatar
nice coloration goign on there
Golfball
Welding / Fabrication
14
Dec 20, 2011 08:41 AM
boosted420
Mid-Atlantic (Sales)
Mar 4, 2008 12:36 PM
t3t41.8tgti
Jun 18, 2007 02:16 AM
Cain Marko
Sep 7, 2004 12:40 PM
Sketch_hs
Jul 15, 2004 09:17 AM
