b7 block y8 head...i need help fast
Old Nov 25, 2005 | 08:51 AM
TehMan's Avatar
Default b7 block y8 head...i need help fast
i need to know how to wire up the vtec solenoid. thats the only thing holdin me back from gettin it done.
________
MARY JANE
Old Nov 25, 2005 | 09:07 AM
BauleyCivic's Avatar
Risky Business
Default Re: b7 block y8 head...i need help fast (TurboEJ2)
I'm assuming this is in a 92-95 civic...
Theres one wire coming off of the solenoid, and two coming off the vtec oil pressure switch. Run the vtec solenoid to pin A4 on the ECU, and run one of the wires from the oil pressure switch to pin D6. The other wire from the oil pressure switch you ground out.
Read these
https://honda-tech.com/zerothread?id=1067906
https://honda-tech.com/zerothread?id=1019014
Old Nov 25, 2005 | 09:14 AM
TehMan's Avatar
Default Re: b7 block y8 head...i need help fast (BauleyCivic)
yes its in a 94 civic...well i just got the solenoid, i didn't get it with the head and i don't have the plugs that plug into the solenoid.
like it came with tap #1 and #4 and #1 is like made into it. i don't have plugs #2 and #3. i can splice the wires on #1 if i had to but i can't with #4 what do i do with it?
________
Republica
Old Nov 25, 2005 | 09:19 AM
Risky Business
#1 is the VTEC solenoid wire...you can cut it before it gets to plug #1 and just run it straight to the ECU if you want.
#2 is the oil pressure switch, a $48 part if you buy it new from honda. Try and find a junkyard and see if you can get one from a civic there. Its a 21mm or 22mm socket I can't remember. You can see there are two wires coming off plug #2, #4 is just the ground wire for it.
Old Nov 25, 2005 | 09:22 AM
TehMan's Avatar
thanks for clearin up the #1 problem. but the other problem is that i have #4 which is the one that is tapped into the solenoid. i don't have #1 that plugs into it that has the 2 wires comming out of it.
________
YAMAHA XV250
Old Nov 25, 2005 | 09:24 AM
Risky Business
can you get a better pic? #4 looks like its coming off the #2 plug and is just being grounded into the solenoid
Old Nov 25, 2005 | 09:48 AM
TehMan's Avatar
thats #4 and #2 is the thing that plug into it. i don't have #2 that plugs into that. i guess the female tap i dunno.
Modified by TurboEJ2 at 11:03 AM 11/25/2005
________
Friend advice forums
Old Nov 25, 2005 | 09:49 AM
TehMan's Avatar
u thought i ment #4 was the ground wire. no i ment it was the plug on the solenoid
________
Stocks To Buy Now
Old Nov 25, 2005 | 10:03 AM
Risky Business
okay, if you have #4 thats good...just go to a junkyard and grab a plug that looks like it will fit, there are several on hondas that do...i got a yellow one
Old Nov 25, 2005 | 10:04 AM
TehMan's Avatar
think u could get me one and i pay you for it? there are no junkyards close to me. and i don't want to drive an hour to get a plug from a junk yard
________
Swiss cooking
Old Nov 25, 2005 | 10:07 AM
Risky Business
I might have one lying around, i'll get back to you
Old Nov 25, 2005 | 10:10 AM
TehMan's Avatar
cool thanks...if so email me at worldracinginds@yahoo.com
________
Michigan dispensaries
Old Nov 25, 2005 | 10:14 AM
TehMan's Avatar
oh one more thing. would it be safe to run the combo with out the solenoid hooked up? well atleast until i get the plugs? cuz this is my daily driver lol
________
Wellbutrin Injury Lawyer
Old Nov 25, 2005 | 10:15 AM
Risky Business
Yeah, just run the DX ecu on it...you'll be fine
Old Nov 25, 2005 | 10:16 AM
TehMan's Avatar
thanks alot man you've been the most help out of every other forum.
________
Vortec Engine
Old Nov 25, 2005 | 05:28 PM
TehMan's Avatar
if i take the oil pressure sensor/switch and put audio clips on the two nipples inside the sensor/switch and run wire to them will it work? and just ground one and run the other? like this...
^i couldn't find any pics so i made one but you see what i mean? if i took the clip and put a wire in it and hooked it to the nipples in the sensor...would i work if i electric taped it so it wouldn't fall off? just for time being...
________
Full melt hash
Old Nov 25, 2005 | 06:43 PM
TehMan's Avatar
ttt
________
The iolite
Old Nov 25, 2005 | 07:49 PM
TehMan's Avatar
bump
________
Vapir Oxygen
Old Nov 26, 2005 | 11:11 AM
TehMan's Avatar
bump ttt
________
Expert insurance
Old Nov 26, 2005 | 12:11 PM
Risky Business
Yes you can do that
Old Nov 27, 2005 | 11:52 AM
TehMan's Avatar
can i use my B7 head studs or do i have to use the y8 ones?
________
Zx14 Vs Hayabusa
Old Nov 27, 2005 | 12:10 PM
TehMan's Avatar
ttt
________
Walther pre filled disposable gram tanks
91 DA Revived
Oct 28, 2010 05:25 PM
JSPECSIR
Oct 7, 2008 06:56 PM
jdmbreed
Sep 26, 2005 07:56 AM
iphatcrxi
Mar 7, 2005 09:52 PM
TheHatchHog
May 1, 2003 03:30 PM
