DAY 2: Swap is about 60%
Old Nov 24, 2005 | 06:22 PM
fasterthenmost's Avatar
Default DAY 2: Swap is about 60%
Well I kept at it determined to put the engine in alone and
save myself some money. Axle nut problem has been fixed
due to assistance with a grinder. I just cut the bolt and will replace.
Here is what it looks like now...
All I have left is:
put the suspension back together
Put the axles in
put the engine harness on
attach shift linkage
re-do (1) lower ball joint
install P75 ECU
I think thats about it and one last thing "pray it starts"
If anyone has any tips or things i should look out for let me know...
Thanks H-T for all your help!!!!!!!!!!!
Old Nov 24, 2005 | 06:26 PM
litterbox's Avatar
I am a (Trial User) Army
Default Re: DAY 2: Swap is about 60% (fasterthenmost)
You forgot you need to re-attach the exhaust.
What's that blue wire that runs along the firewall? Looks good so far now man.
Old Nov 24, 2005 | 06:28 PM
mike93eh
Guest
Posts: n/a
Default Re: DAY 2: Swap is about 60% (litterbox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">You forgot you need to re-attach the exhaust.
What's that blue wire that runs along the firewall? Looks good so far now man.</TD></TR></TABLE>
looks like amp wire..
Old Nov 24, 2005 | 06:33 PM
litterbox's Avatar
Default Re: DAY 2: Swap is about 60% (mike93eh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh &raquo;</TD></TR><TR><TD CLASS="quote">
looks like amp wire..</TD></TR></TABLE>I wanted him to answer so I could make fun of him (in a nice way)
Old Nov 24, 2005 | 06:46 PM
yeah its for an amp.
its not the best but gets the job done...
imma try to finish it all up tommorrow.
i will keep ya posted..
Old Nov 24, 2005 | 06:50 PM
litterbox's Avatar
Default Re: (fasterthenmost)
There's a grommeted hole right behind the battery, wire it through that.
Good luck with the rest of it.
Old Nov 24, 2005 | 07:10 PM
ThefirstPACT's Avatar
Default Re: (litterbox)
I have one suggestion next time out the harness on before you put the motor in! You can make it a little cleaner and you can get every angle with out much trouble! That's how I do it anyways! for doing it yourself!
Dutch
Old Nov 24, 2005 | 07:11 PM
komat's Avatar
why didnt you put the header on first b4 putting the motor in the car?
Old Nov 24, 2005 | 07:19 PM
95DxSi-R2
Guest
Posts: n/a
Default Re: (ThefirstPACT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThefirstPACT &raquo;</TD></TR><TR><TD CLASS="quote">I have one suggestion next time out the harness on before you put the motor in! You can make it a little cleaner and you can get every angle with out much trouble! That's how I do it anyways! for doing it yourself!
Dutch</TD></TR></TABLE>
definetly (harness)
Old Nov 24, 2005 | 07:25 PM
my_slow_civic's Avatar
Double check EVERYTHING before start up. Mentally go through your checklist.
Old Nov 24, 2005 | 07:35 PM
ekcivic9's Avatar
is this the first time you've ever done something this big? was it hard?
Old Nov 24, 2005 | 07:46 PM
92Jspec's Avatar
I second that
Old Nov 24, 2005 | 08:16 PM
SkRiBLaH's Avatar
Default Re: (92Jspec)
wow.
1st swap? i did my first swap in one night...alone. but the tools you have and environment does make a differance.
civic92vx
Jun 29, 2010 09:55 AM
sde780
Jul 8, 2009 10:51 AM
tek_civic
May 14, 2006 02:04 PM
MonkeyPuzzle
Aug 16, 2005 09:26 AM
