ALL EK H22s with midrange VIBRATION!!!!
just wondering if anyone else has the problem that i have, In first and second gear and even sometimes in third i have a vibration feeling through the lower to midrange RPMs and as the car reaches above 4500 it goes away. I have Hasport EKh1 mounts and hasport axles. i have read that the axles are to long and bind causing vibration. i have already sent my axles back to hasport for replacement but hasport did nothing to shorten the axles and simply sent me on new axle (the same size) because of a bad inner joint. the vibration still continues, what have others done to solve their problem, i would be thankful for some advice. Im just so pissed with the situation. i spent all this damn money and i still have problem. i even replaced the wheel bearings and lower ball joints. i have an EK9 with a H22a.
I had a H22 Ek and I never had vibration problems, but I from what I have seen alot of people that have axle vibration problems try adjusting the ride hight of there cars (change the angle on the CV joint)
BTW I did read that you already had the axels checked. Just my $.02
