Cleaning Valve Cover
Old Nov 23, 2005 | 03:22 PM
VTECisSeXY's Avatar
*insert here*
Default Cleaning Valve Cover
Possibly a dumb **** question. And yes I did search.
Whats the best thing to clean a valve cover? I really dont know what works best and was wanting some hints
thanks
Old Nov 23, 2005 | 03:46 PM
InvaderTrax's Avatar
Depends on how clean you want it. Just to make it look good? Or do you plan to paint it? I usually use a paper towel with a little oil on it to clean up mine. If you want to paint it, sand it down, then clean it with rubbing alcohol, then a dry cloth
Old Nov 23, 2005 | 04:56 PM
KaoSyN's Avatar
Default Re: Cleaning Valve Cover (VTECisSeXY)
Also, after degreasing and washing my engine I like to spray armor all everywhere and then turn on the car and let it sink in. Comes out pretty nice. I did notice the other day though when I was racing without an oil cap (dont ask) oil does indeed make it looks nice and shiny too.
Old Nov 23, 2005 | 05:32 PM
VTECisSeXY's Avatar
*insert here*
Default Re: (InvaderTrax)
paper towel with oil on it? hmm, never tried that. Wouldnt that do the opposite?
I definetly dont want to paint it
Old Nov 25, 2005 | 02:26 PM
VTECisSeXY's Avatar
*insert here*
Default Re: (VTECisSeXY)
Old Nov 25, 2005 | 06:23 PM
MNsnowdaboy's Avatar
Dude you gotta be crazy using oil to clean the car. You ever see a motor that leaks oil and then get dirt on it, it turns into scum.
Here's what I do and most people has never even thought about but I'll share some info.
Clean your valve cover however you want it and then for the finishing touch use some "Foam" tire cleaners. They will eat up all the little dust and dirt and make you valve cover bling bling. One important thing is your motor/valve cover cannot be hot.......keep that in mind.
I also use this on the whole engine bay, makes hoses and little things that are black bling bling. Give it a shot, it won't hurt.
Old Nov 26, 2005 | 08:08 AM
Turbo-GSR1287's Avatar
Default Re: (MNsnowdaboy)
wow i woulda never thought of the tire foam stuff to clean the engine bay......that is awesome!
Old Nov 26, 2005 | 09:07 AM
Buffalo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MNsnowdaboy &raquo;</TD></TR><TR><TD CLASS="quote">Dude you gotta be crazy using oil to clean the car. You ever see a motor that leaks oil and then get dirt on it, it turns into scum.
I also use this on the whole engine bay, makes hoses and little things that are black bling bling. Give it a shot, it won't hurt.</TD></TR></TABLE>
Old Nov 26, 2005 | 05:00 PM
linkin's Avatar
im'a give that a shot haha
Old Nov 27, 2005 | 01:03 AM
Haha like I said not a lot of people even thougt about this stuff. One day I was bored and kept thinking how come the engine bays at the dealers are so bling bling. I kept thinking of what I can use to is similar to what they have, which I don't know what they use though.
Then I thought about this tire foam and how it cleans tires. At first I was scared that it'll be to strong and eat the valve cover away but after a while thinking, that "GUNK" degreaser is pretty strong itself, so it shouldn't be a problem and used it. Well the rest is history, you gotta use it and look at a black valve cover with the sunlight shining on it. It's just like at the dealers I tell you.
Just remember to not use it when the motor is hot, I found that out that it'll just eat the foam right away. You actually kind of get a little stain from the foam melting away if the engines hot.
To people that is doing this for the first time, let me know if it works for you guys too. Also let me know if you guys already know this trick or did you hear it from me first. I just want to know because I'm hoping that my stupid mind actually helped some people out and it wasn't wasted on day dreaming about a nice valve cover..... I'm not trying to brag or anything but if anyone else have been doing this already I'm curious to know how they came up with it. I've been doing this since 1999 when I had my B16a CRX.
Old Nov 27, 2005 | 08:19 AM
LudeyKrus's Avatar
I clean mine with spit and a toothbrush.
to all the lazy ricers.
Old Nov 27, 2005 | 09:00 PM
Default Re: (LudeyKrus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">
to all the lazy ricers.</TD></TR></TABLE>
Care to elaborate on what that ment?
Old Nov 27, 2005 | 09:09 PM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">I clean mine with spit and a toothbrush.
rofl.......hardass
Old Nov 27, 2005 | 09:24 PM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
Default Re: (98vtec)
damn i gotta try that my type s valve cover all ways gives me hell tryin to clean it i keep thinking its goin to take the paint off
Old Nov 27, 2005 | 09:28 PM
98vtec's Avatar
moderator emeritus
Default Re: (raylude)
i use soap and water on my type s
Old Nov 28, 2005 | 08:00 AM
VTECisSeXY's Avatar
*insert here*
howd it turn out?
Old Nov 28, 2005 | 09:58 AM
johnca's Avatar
A while back I had two hoses bust on me one after the other. my cai got doused with water and antifreeze mixture. At the time, I was too worried about my car turning to crap to worry about my wet dirty cai tube. now, it has water spots that wont go away, so I was wondering if that tire foam cleaner might work, or will it ruin it?
Old Nov 28, 2005 | 10:07 AM
mgags7's Avatar
a powerwasher and a quick grind on the raised letters will clean up the outside nicely
the inside can be cleaned with gas and a brush
Old Nov 29, 2005 | 08:26 AM
I've been doing this for 6 years with no problems but this is with the stock black. Not sure about the red type s but shouldn't be any difference.
Old Dec 6, 2005 | 04:45 PM
Just resprayed my engine bay with the Tire Foam and it's still bling bling.
Old Dec 6, 2005 | 08:34 PM
DIRTYsouthBB6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MNsnowdaboy &raquo;</TD></TR><TR><TD CLASS="quote">Just resprayed my engine bay with the Tire Foam and it's still bling bling.</TD></TR></TABLE>
Which tire foam do you use?
While we're on this subject, my engine block and the outside of my cylinder head have stains and whatnot ( not grease or dirt, but th emetal is stained ) all over it. Anyone have any tips to make my rough aluminum look clean and new again?
Old Dec 6, 2005 | 08:50 PM
mgags7's Avatar
yeah engine shops do the same thing before shipping out motors, a steam cleaning, then a spray over with degreaser, really shines everything up....well the good ones do that at least....
Old Dec 7, 2005 | 04:04 PM
Any tire foam will work but just get a good quality one. As for the engine being stained, your only hope if to get it steamed clean if you really want that brand new shiny aluminum look.
Old Dec 15, 2005 | 08:50 PM
EJ1_203's Avatar
Default Re: (johnca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnca &raquo;</TD></TR><TR><TD CLASS="quote">A while back I had two hoses bust on me one after the other. my cai got doused with water and antifreeze mixture. At the time, I was too worried about my car turning to crap to worry about my wet dirty cai tube. now, it has water spots that wont go away, so I was wondering if that tire foam cleaner might work, or will it ruin it?</TD></TR></TABLE>
about the cai u can use neverdull u can purchase at pepboy or ur local automtive shop its works mint cleans all metal !
Anthony Miller
Feb 3, 2019 06:43 PM
ReVeNgEd-SoN
Feb 20, 2010 10:33 PM
Weapon
May 22, 2006 07:29 AM
eL
Jul 11, 2004 11:02 AM
ramz7887
Sep 13, 2003 07:47 AM
