Need help with Sensor on cat....
I was trying to install my exhaust but when the bolt came off the exhaust came with it... it pulled out 4 little wires from a sensor on the top of the cat toward the engine side.... What should i do? Can i just re insert them? I had a guy tell me i needed to get a whole new harness and all this ****.... hmmmm.... heres teh pic... [IMG][/IMG]
yeah you can just plug the back in the connector, assuming it's not damaged. Just make sure you get them in the right spots on the connector.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kchungb17a »</TD></TR><TR><TD CLASS="quote">yeah you can just plug the back in the connector, assuming it's not damaged. Just make sure you get them in the right spots on the connector.</TD></TR></TABLE>How do i know if its damaged? And more importantly how do i know where they go? Thanks...
i've done this like 4 times. everytime i forget about the damn sensor and pull the pins out. lol.
anyway, i just plugged the pins in matching them by their wire colors. if you look at the connector from the back with the wires untwisted it's easy to match up to the wires on the other side of the connectors. if you've got two matched up in a square, (green to green, white to white) the black wire coming out of the sensor next to the green wire gets plugged in next to the green wire on the connector. i hope that makes sense.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NuclearB18B »</TD></TR><TR><TD CLASS="quote">i've done this like 4 times. everytime i forget about the damn sensor and pull the pins out. lol.
anyway, i just plugged the pins in matching them by their wire colors. if you look at the connector from the back with the wires untwisted it's easy to match up to the wires on the other side of the connectors. if you've got two matched up in a square, (green to green, white to white) the black wire coming out of the sensor next to the green wire gets plugged in next to the green wire on the connector. i hope that makes sense.</TD></TR></TABLE>Ummm hahaha, i was more confused than when i got high for the first time and my brother and his friend told me i just smoked dried banana peels and nutmeg... But thanks, i got a knowledgable guy to help so
