Need help finding a wire....
Old Nov 23, 2005 | 01:01 PM
GtechPro's Avatar
Default Need help finding a wire....
I'm working on an RPM pick-up project. I got the MSD 8918 GMR pickup unit and I'm supposed to attach it to the Inductive ignition coil primary wire. Well, i did and it didn't work. It worked when i attached it to one of the spark plug cable wires, but the signal wasn't good enough.
I actually tried it on all ignition coil wires, but with no luck.
Now i don't know if this thing just doesn't work or if i didn't attach it to the right wire.
So here is my question:
Where exactly is this primary wire? Maybe i lost my mind and had the wrong wires this whole time.
Car is a 94 Civic HB with a 97 JDM ITR motor. OEM ignition.
Please reply if you know
Old Nov 23, 2005 | 01:30 PM
MeatballHB's Avatar
Default Re: Need help finding a wire.... (GtechPro)
Uhm, when I hooked up my tach on my 97 Civic HB, the BLUE ignition coil wire was Negative...
...If that helps any =/
Old Nov 23, 2005 | 06:02 PM
GtechPro's Avatar
Default Re: Need help finding a wire.... (MeatballHB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MeatballHB &raquo;</TD></TR><TR><TD CLASS="quote">Uhm, when I hooked up my tach on my 97 Civic HB, the BLUE ignition coil wire was Negative...
...If that helps any =/</TD></TR></TABLE>
That was the first wire i tried... Didn't work...
I'm confused now.
Thanks anyway
Old Nov 23, 2005 | 06:18 PM
MeatballHB's Avatar
Are you trying to wire a tach?
vtek9
Aug 27, 2007 07:40 PM
Silver.007
Oct 12, 2005 06:50 AM
vegaskurt
Oct 4, 2005 01:29 PM
vteckilla7
Aug 18, 2004 06:29 AM
dirtySOHC's
May 22, 2003 07:15 PM
