What does Lapping means??
Old Nov 23, 2005 | 11:34 AM
max23's Avatar
Default What does Lapping means??
I was browsing around on ebay, found a 2000 Civic EX SOHC vtec head with everything but the camgear, the seller said it been cleaned, everything been taken apart such as the: that from his listing
-the head itself
-Sandblasted d16y8 valve cover (never used)
-Vtec Solenoid (yes it works)
-all rocker arms, lost motion assembly, bolts
-all valve seals installed
- all valves, springs, retainers, and keepers.
-cam
here what he said from his reply after i was asking him if there anything that need to be worked on or anything i need to know of:
Yes everything but the cam gear is present with the head.
The valves, cams and rocker arms have been removed from the head. the valves are in individual numbered bags so that you can put them back in their original place. I would however recomend that you lapped them anyway since its cheap insurance to make sure you have a solid well sealing head. Any machine shop can do this for you (for rather cheap) or you can do it yourself with about 50 dollars worth of tools (spring compressor, lapping tool, lapping paste).
any of you honda Guru's can tell me if this a safe buy ?? is it worth the trouble to work on it and fully assemble it ?? also what does lapping means?? can you guys define it what it means and what kind of work is it being done to it??
thanks guys!
Old Nov 23, 2005 | 11:42 AM
si0385.'s Avatar
Default Re: What does Lapping means?? (max23)
u put the valve on the end of that like a suction cup and spin it on the head... kinda sets the valve in place
TravisCadello
Jun 30, 2011 08:30 AM
5speed4life
Dec 15, 2009 06:14 PM
K2e2vin
Nov 26, 2006 09:02 AM
kyle h.
Mar 27, 2003 06:51 AM
inspyral
Mar 14, 2003 02:57 PM
