installing things.. help ?
Old Nov 22, 2005 | 11:42 PM
Fugun's Avatar
Default installing things.. help ?
ok i got a autometer shiftlight... and i was curious what do you guys feel is the best tach wire to use?
my friend was running his from behind his gauge with a 7.8 pill... the light would turn on at 8.1 oh the tach, even though the pill says 7.8 which would you trust? any one know of a better wire?
also, installing a autometer AF gauge... what is the best wire to tap for that thing too ? the ECU ?
Old Nov 23, 2005 | 01:27 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: installing things.. help ? (Fugun)
There are a few tach wires in the vehicle. One behind the cluster, one at the ECU and one at the distributor. Any of these should read the same signal.
Old Nov 23, 2005 | 01:50 AM
1sikhatch's Avatar
Default Re: installing things.. help ? (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">There are a few tach wires in the vehicle. One behind the cluster, one at the ECU and one at the distributor. Any of these should read the same signal.</TD></TR></TABLE>
there's also the blue wire right behind the firewall on the drivers side for the tach.
also i heard its best to tap the a/f wire closest to the ecu.
Old Nov 23, 2005 | 02:00 PM
Fugun's Avatar
Default Re: installing things.. help ? (1sikhatch)
alright, hrm
well 1 sikhatch... for the blue wire for tach signal., is that the one going into a deadend plug?
by the driverside shock tower?
thanks for your help guys
ohh do u know a godplace to get wire diagrams ?
Old Nov 23, 2005 | 03:24 PM
eastsidekustomz's Avatar
i tapped my tach wire right at the distributor, and for my A&gt;F gauges, i tapped direcly to the 02 sensor wire carefully, so that i get both signals right direct from the source. as to not let any other electronics or anything add the slightest bit of amperage for the truest reading. all electronics in cars give off or take a little more power once they are running a signal through the electronics in it. so best bet for a true reading would be directly connecting next to the source.
Modified by eastsidekustomz at 11:42 PM 11/25/2005
wood
Mar 26, 2005 02:49 PM
b20guy
Apr 11, 2003 05:12 PM
MattsHatch93
Dec 1, 2002 10:09 AM
civicracer1993
Sep 17, 2002 10:53 PM
xXx Justin xXx
Jun 13, 2002 07:20 PM
