how do i remove front bumper cover?
i have the two screws out in each fender, and the bolts behind each corner light and then the one in the middle of the radiator. need help!!!
three screws under hood, one screw behind corner light, and two screws in the hinge part of the door... one on the bottom, one on the top.
ohhhh bumper cover.... three screws across the top where the hood latch is, one under each corner light, and two on each side in front of each wheel.
You have to remove the plastic piece between the hood and the filler plate.
Which I believe is 2 phillip head screws.
Then remove the filler plate, two 10mm under the corners, 2 10mm on the inner side of each headlight.
Then three screws across the top,
Two screws on each side by the front tire.
and then your done.
and then your done.
newhondaowner29
Honda Civic (2006 - 2015)
Jan 2, 2011 11:47 AM
Bay Area EF9
Dec 28, 2008 03:14 PM
anybody know?
