has anyone boosted hondata/3bar over 28lb
AFAIK the 3 bars are only good up to 29 psi. To get the capacity for a MAP sensor you subtract 1 bar from it's rating, then multiply the remainder by 14.5 or 14.7 (I forget which). (3-1) x 14.5 = 29 psi or 29.4 psi if you multiply by 14.7.
EDIT: another way to do it is convert BAR to psi then subtract 14.7 psi. That will tell you about how much psi the MAP sensor can handle.
we are running a 3 bar on an Accel DFI gen 7. i belive the computer cant read a 5 bar or something? im not sure, but we have hit 50 psi on it, and its still working properly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoOstedEM1 »</TD></TR><TR><TD CLASS="quote">Not be rude or thread jack, where is the best place to get a 5 bar.</TD></TR></TABLE>
AEM
AEM
B00stedCoupe
Nov 16, 2003 03:41 PM
