Collector techniques.
Old Nov 20, 2005 | 09:23 PM
MidShipCivic's Avatar
Default Collector techniques.
I found this picture on a VW board..
How do you cut and bend tubing like that?
Old Nov 20, 2005 | 09:25 PM
LD_EGSICK's Avatar
Default Re: Collector techniques. (MidShipCivic)
you might want to do a search first. there is alot of posts about it
Old Nov 20, 2005 | 09:36 PM
ophdehEEEzy's Avatar
I'm wondering, if the difference would be noticeable when comparing tube-style collectors with box-like collectors like the one below:
besides it being ugly, for do-it-yourselfers.. it's really easy.
Old Nov 20, 2005 | 10:04 PM
Default Re: Collector techniques. (LD_EGSICK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LD_EGSICK &raquo;</TD></TR><TR><TD CLASS="quote">you might want to do a search first. there is alot of posts about it</TD></TR></TABLE>
Tried that buddy, just help me out if you can find it .
I dont think transition like that are ideal when making a manifold.
Old Nov 20, 2005 | 10:09 PM
Ekasey's Avatar
Default Re: Collector techniques. (OH ISH ITS DAT FOOL JAMES)
Defintley a large difference if the header behind it is designed correctly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidShipCivic &raquo;</TD></TR><TR><TD CLASS="quote">I found this picture on a VW board..
not sure if im understanding your cuqestion right but to do have a bend in the collector you usually fabricate with pre bent tubing
Old Nov 20, 2005 | 10:13 PM
Yeah basically I would like to know how to make one.
I've asked one manifold builder and he got all butt raped about ppl stealing designs from him...
I thought I was asking a general question? Oh well nevermind him.
So basically in this picture the tubing was actually a bend basically with a bunch half cuts?
Old Nov 20, 2005 | 10:20 PM
Ekasey's Avatar
Default Re: (MidShipCivic)
yep
Old Nov 21, 2005 | 02:51 AM
Dragline's Avatar
So basically in this picture the tubing was actually a bend basically with a bunch half cuts?</TD></TR></TABLE>
In that pic I'm not see this bend you guy's are talking about, that collector is cut from straight sch.40 pipe.
Old Nov 21, 2005 | 08:24 AM
splitime's Avatar
Default Re: (Dragline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dragline &raquo;</TD></TR><TR><TD CLASS="quote">In that pic I'm not see this bend you guy's are talking about, that collector is cut from straight sch.40 pipe.</TD></TR></TABLE>
Yah, there is at LEAST one post i remember with someone doing a walkthrough on DIY collectors. He made a simple jig to cut the straight pieces 2x at the desired location/angle. do that 8x (2x per piece) and then fit up and weld. If the measurements/cuts were accurate, it'll line up nicely.
Old Nov 21, 2005 | 09:41 AM
RCautoworks's Avatar
Good luck finding any answers. People like to keep these things secret.
Old Nov 21, 2005 | 10:15 AM
Race Egr's Avatar
Default Re: Collector techniques. (90blackcrx)
Just make some kind of jig all you have to do is take 4 equal length pieces of pipe and cut them on 2 sides 90 degrees apart from each other at the same angle
Old Nov 21, 2005 | 11:03 AM
http://www.fab-forum.com/forum...&PN=1
Old Nov 21, 2005 | 01:36 PM
snoochtodanooch's Avatar
everybody is still making a big deal outa this? I will have to look around for that DIY
Old Nov 21, 2005 | 01:44 PM
cstay's Avatar
Default Re: Collector techniques. (snoochtodanooch)
buy some pvc pipe 1.5 inch sched 40 and expermint with jigs and when you figure it out cut steel its not that hard
Old Nov 21, 2005 | 01:50 PM
Default Re: Collector techniques. (cstay)
Old Nov 21, 2005 | 03:08 PM
I would've thought casey would know ? Looks sure to me :-\ .
Old Nov 21, 2005 | 03:13 PM
Bailhatch's Avatar
ya there are several posts about it. I even MS painted a pic of my collecter jig for a band saw.
Old Nov 21, 2005 | 03:14 PM
Default Re: Collector techniques. (Casey@Burns)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Casey@Burns &raquo;</TD></TR><TR><TD CLASS="quote">Defintley a large difference if the header behind it is designed correctly</TD></TR></TABLE>
What are you talking about here ?
Old Nov 21, 2005 | 03:15 PM
Ekasey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">
What are you talking about here ?</TD></TR></TABLE>
A box style collector versus a merge
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidShipCivic &raquo;</TD></TR><TR><TD CLASS="quote">I would've thought casey would know ? Looks sure to me :-\ .</TD></TR></TABLE>
?? im confused we dont use a fixture to cut our tubes
Old Nov 21, 2005 | 03:16 PM
powerofdreams8's Avatar
There are no bends, its just two cuts on a straight piece of pipe. The angle and spacing I do not know.
Old Nov 21, 2005 | 03:17 PM
Default Re: (Casey@Burns)
mmmm what exactly to you use to make those fancy pants collectors ?
Old Nov 21, 2005 | 03:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidShipCivic &raquo;</TD></TR><TR><TD CLASS="quote">mmmm what exactly to you use to make those fancy pants collectors ?</TD></TR></TABLE>
Did you read the link I posted
Pretty sure Casey is not going to take pictures of the jigs they use, or how they do things.
Old Nov 21, 2005 | 03:22 PM
Ekasey's Avatar
Hands a band saw and lots of time....... can't say much more
Old Nov 21, 2005 | 03:26 PM
Default Re: (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Did you read the link I posted
Pretty sure Casey is not going to take pictures of the jigs they use, or how they do things. </TD></TR></TABLE>
I read your link.
That's okay because it isn't a good idea for him to show me, I'll find out sooner or later.
Old Nov 21, 2005 | 03:28 PM
I read your link.
What do you want, a step by step guide ?
That's okay because it isn't a good idea for him to show me, I'll find out sooner or later.</TD></TR></TABLE>
lol what else do you want to find out ? Everyone already told you how there made, I posted a link to show you with pictures.
I don't really think there is anything else to find out .
