Anyone using Hasport mounts and NO torque mounts
Old Nov 20, 2005 | 06:46 PM
lupin5's Avatar
Default Anyone using Hasport mounts and NO torque mounts
I have the Hasport mounts but am debating not running the lower torque mounts. I have a EJ1 w/B18C that will be turbocharged (450+). Wonder if it's ok to run without the torque mounts. Am I going to damage anything? Or should I just put them on. Kinda wanted to clean up the enginebay alittle more. Anyone with experience?
Old Nov 20, 2005 | 06:50 PM
Luserkid's Avatar
Default Re: Anyone using Hasport mounts and NO torque mounts (lupin5)
Im getting the Hasport kit to get ried of those mounts. If i wanted to keep them i would just get inserts.
If you had AC then youll keep the one on the motor.
Old Nov 20, 2005 | 07:36 PM
b18cKoupe's Avatar
Default Re: Anyone using Hasport mounts and NO torque mounts (Luserkid)
i have a 94 coupe with a b18c w/ the hasport mounts(street) with no lower mounts and my motor doesn't move at all. As luserkid said to keep AC you'll need the driverside lower mount.
Old Nov 20, 2005 | 07:46 PM
lupin5's Avatar
Default Re: Anyone using Hasport mounts and NO torque mounts (b18cKoupe)
I dont have AC or PS. I was just worried the added weight of the turbo, mani and other stuff.
i guess I'll try it and see how it goes. I hope I wont have a problem.
Old Feb 12, 2007 | 09:18 PM
DFW's Avatar
DFW
Old *** thread I know, but I'm thinking about doing the same, different mounts but they have 75a inserts. Anyone else doing this?
Old Feb 12, 2007 | 10:05 PM
usdmEHboy's Avatar
Default Re: Anyone using Hasport mounts and NO torque mounts (DFW)
hmm i curious...i just did my swap with hasport mounts also...but put both the mounts on...do i really need them on?
Old Feb 12, 2007 | 10:32 PM
ekb16's Avatar
the hasport mounts are more than enough...they are rock solid and your engine will not move even with just 3 of them
Old Feb 13, 2007 | 01:09 AM
Projekt_2nr's Avatar
i mount ny old h-swap without torque dampeners and i had no motor jolting issues
Old Feb 13, 2007 | 06:08 AM
Jay_Sensing's Avatar
Never had an issue on my way old nitrous car or my last turbo car and both of them made plenty of power. That's why I love Hasport.
Old Feb 13, 2007 | 07:04 AM
jdmdelsolsi's Avatar
i have hasport street series mounts, and no lower mounts and my motor dont move at all. so i say nay on that one.
B_Swapped93
Oct 28, 2013 06:22 AM
Muckman
Jul 16, 2011 02:39 AM
Powered by VTEC
18
Dec 22, 2007 06:14 AM
JFG Kevin
Jan 12, 2007 07:33 AM
DonPapadapolis
Apr 23, 2005 08:51 PM
