Headunit in ek civic getting hot
Old Nov 20, 2005 | 05:54 PM
nate1821's Avatar
Default Headunit in ek civic getting hot
I always noticed this in all eg and ek civics, in the winter time. Seems that the heat from the vent above will heat the crap out of the headunit.
My new pioneer is even starting to skip when it gets really hot. When the cd comes out its to hot to handle for a while.
Does anyone else have this problem? Has anyone tried wiring a fan, maybe from a computer to keep it cool?
Old Nov 20, 2005 | 06:54 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Just put a cpu fan in there and it shouls really help, I have had no problems before, thanks for bring this to my attention.
Old Nov 21, 2005 | 01:12 PM
fcm's Avatar
fcm
Old Fart
Default Re: Headunit in ek civic getting hot (nate1821)
I have an Alpine HU in my 94 teg LS, that used to get hot, I modified, [stripped down] a 12V hair drier, installed it behind glove box, ran some flex hose to behind and below the HU and have the 2 speed switch mounted below the glove box, [temporary as I want the replace it with "thermo" switch/s] have not had an overheating problem since.
One thing I would do if you haven't already, is for the HUs constant power, [yellow] run a fused 12ga or 10ga fused power wire from the batt. to behind the HU and connect the constant, [yellow] to it, and add a 12ga or 10ga ground wire from the chassis of the HU the the cars chassis, the oem radio harness constant power and ground are not sufficient for today's "high power" HUs. 94
5pointer
Jun 17, 2012 09:40 AM
awtay
20
May 2, 2012 05:36 PM
lampshadej1
Jun 22, 2010 01:48 PM
Benj
Oct 14, 2002 06:53 PM
