OK, 1st post here....
Old Nov 20, 2005 | 01:26 PM
brmiddle's Avatar
Default OK, 1st post here....
just bought a 93 VX hatch and was looking at the JDM fogs that go in the bumper for my car and have a couple of questions.
Do they fit in the stock bumpers and do i just take out the black grills and pop hem in?
Is there a vendor here that sells them on this forum with the whole kit including the harnesses and the switch?
Thx for your help1
brian
Old Nov 20, 2005 | 01:33 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: OK, 1st post here.... (brmiddle)
E-Bay for teh winnzor!!! They will run you about 80 - 100 bucs on E-bay for a stock switch, wiring harness, and fogs/cover.
The wiring harness that comes with these is shitty and the fuse will melt everytime after a certain time span of use. Just check it every now and then and make sure it has not completely fucked up the system. Sometimes the fog's wont work because the fuse melts so bad.
Yes, you just cut out the "blocker" part of the bumpers and they fit right in, no problem.
Old Nov 20, 2005 | 01:37 PM
brmiddle's Avatar
thxs for the help, i can just wire in a better fuse then and worry a little less.
Old Nov 20, 2005 | 01:46 PM
H-T Poker champion
Default Re: (brmiddle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brmiddle &raquo;</TD></TR><TR><TD CLASS="quote">thxs for the help, i can just wire in a better fuse then and worry a little less. </TD></TR></TABLE>
Yea, that's what my brother ended up doing with his. I still fight with mine though!
You're welcome for the help.
kcari
Honda Civic (2001 - 2005)
19
May 11, 2013 05:00 PM
born2sleep13
15
Oct 26, 2011 06:40 AM
xjm92x
13
Apr 19, 2011 07:59 PM
EcivicG
Dec 31, 2008 03:29 PM
ckkl
Nov 6, 2002 01:42 AM
