back passenger side wheel is wobbling
Old Nov 20, 2005 | 02:54 AM
Supraznki's Avatar
Default back passenger side wheel is wobbling
what could be the cause of this?
Old Nov 20, 2005 | 06:06 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: back passenger side wheel is wobbling (Supraznki)
You either have a bent rim or there is corrosion on the hub face causing runout. Raise the car an spin the wheel. If the brake rotor also wobbles, it is the hub. If just the wheel wobbles, it is the rim.
Old Nov 20, 2005 | 06:43 AM
LL2009's Avatar
Default Re: back passenger side wheel is wobbling (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">You either have a bent rim or there is corrosion on the hub face causing runout. Raise the car an spin the wheel. If the brake rotor also wobbles, it is the hub. If just the wheel wobbles, it is the rim.</TD></TR></TABLE>
also check the shock it could bad.
Old Nov 20, 2005 | 08:26 AM
numbnuts22715's Avatar
the lug nuts could be loose
Old Nov 20, 2005 | 08:50 AM
nitrofish420's Avatar
Default Re: back passenger side wheel is wobbling (LLEO245)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LLEO245 &raquo;</TD></TR><TR><TD CLASS="quote">
also check the shock it could bad. </TD></TR></TABLE>
It's not the shock. You either have a loose/bent wheel, a bad tire, a bent hub or bad wheel bearing. But if it was the bearing, you would've heard noise long before having wheel runout.
Old Nov 20, 2005 | 09:21 AM
Supraznki's Avatar
Default Re: back passenger side wheel is wobbling (nitrofish420)
yea its probably the bent wheel , any idea what will happen if i continue riding with it?
Old Nov 21, 2005 | 04:45 AM
Supraznki's Avatar
anyone?
Old Nov 21, 2005 | 05:17 AM
Dogginator's Avatar
Daisy... Daisy...
It could fail.
Old Nov 21, 2005 | 06:13 AM
Supraznki's Avatar
like what could be damaged? besides the already bent wheel
Old Nov 21, 2005 | 11:47 AM
RevOnRacerz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Supraznki &raquo;</TD></TR><TR><TD CLASS="quote">yea its probably the bent wheel , any idea what will happen if i continue riding with it?</TD></TR></TABLE>
I sometimes wonder about the people who ask this question. Do you really want to keep riding on it? i mean your wheel is FLICKED up and wobbling. worst case scenario? ur wheel falls off while ur taking a turn u flip off the side of a cliff. Is spending a couple hundred bucks to fix it not worth saving ur life? and if not yours, your passenger's or the passengers in the other car u run into after ur car falls apart and spins out of control?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">It could fail.</TD></TR></TABLE>
simple as that and u'd be screwed. get it fixed.
Al-sonic
10
Nov 28, 2007 12:35 PM
RBeckner
Honda Civic (2001 - 2005)
13
Jul 31, 2006 04:14 PM
ice11honda
Suspension & Brakes
Feb 18, 2005 04:54 PM
navin
Dec 9, 2004 04:54 PM
BlackJoker
25
Sep 7, 2003 03:39 PM
