chipping an ecu
Old Nov 19, 2005 | 03:41 PM
zkrobs4's Avatar
Default chipping an ecu
i want to do it myself, but am unsure of how its done. has anyone done it? pics and detailed writeups would be cool
thanks
Old Nov 19, 2005 | 04:43 PM
zap's Avatar
zap
http://www.pgmfi.org
Old Nov 19, 2005 | 05:38 PM
SVOboy's Avatar
Yeah, the library in the pgmfi is where I learned, besides asking lots of questions to various helpful people, good luck.
Old Nov 19, 2005 | 10:19 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (SVOboy)
the easy way to do it for obd0 would be to cut the chip out using fingernail clippers or whatever small clipper oyu can find, and then unsolder the pins one by one, and solder in a socket and use a zif socket on top of that socket. use pgmfi for reference. if you are obd1 you dont have to remove a chip, just insert 2 and set a jumper wire. use pgmfi for reference. its not *that* hard. it might be good to practice on some electronics you dont care about first though.
Old Nov 20, 2005 | 07:06 AM
SVOboy's Avatar
Why put a zif in on top of the dip socket?
Old Nov 20, 2005 | 05:53 PM
HRC69's Avatar
http://home.mn.rr.com/keebler6....html
Old Nov 20, 2005 | 05:56 PM
SVOboy's Avatar
Ah, for added height, I'd not thought about that, it's not really a problem for me to hit the switch with my zifs.
Old Nov 20, 2005 | 06:03 PM
sanimalp's Avatar
$cat /dev/urandom
ive found the dip helps the low profile zif clear a capacitor on the obd0 boards. i havent chipped any obd1 but you probably dont need the dip socket from what it looks like to me. i would much rather have a soldered zif, but on my pm6 board there was not enough room.
disordinate
Engine Management and Tuning
Nov 20, 2008 03:47 PM
dwerpk
Dec 21, 2006 03:11 AM
boosted_hatch_216
Feb 21, 2005 08:41 AM
90teg
Jan 1, 2005 08:01 AM
omahaturbocivic
Aug 1, 2003 10:04 AM
