Lost HKS SSQV adjustment screw - Will any bolt work >>
i lost the adjustment screw on the back of the HKS SSQV bov on a couple hard runs this weekend. i guess i did not have the nut tightened down.
anyway, can i just use any bolt that fits the hole or is there something special with the stock one.
anyone know the length and pitch of it?
thanks
platinum
thanks
platinum
Who is Mr Robot?
i think its an npt bolt... try 1.8th... but the bolt doesnt do ****... why do you think the new ones dont have it
i figured as much..
so i can run without it just fine. i figured i was leaking boost without the screw.
platinum.
platinum.
Who is Mr Robot?
oh wait... it will. lol.... fjust get a 1/8th npt bolt... or weld the hole up
hey my buddy has a ssqv HKS on his car and all of a sudden one day it got really quite and he started gettting surge... this is after he put in a different bolt(idk it had anyhting to do with it considering all thjat bolt does is tighten a spring to hold the valve closed while boositing) but it did and he got a stock dsm bov (2 g plastic cant crush) now and it leaks and he only runs 10 psi as opposed to 16psi
Who is Mr Robot?
it only preloads the spring a few mm or maybe a pound or two... no real improvement when its a pull type valve
well if i get a bolt that is the same length, then it shoudl work the same as the stock one...
i thought she was running a little funny.
platinum.
platinum.
im going to be running around 24 -28 psi.
why would it force the bov open with a bolt in there.
platinum.
platinum.
no i said that kinda weird, If ur running a good amount of boost which you are, your gunna wanna tighten that bolt down a little b/c the presure flowing in the IC pipes can be enough to force the bov open. Inturn causeing you a boost leak
Soo just tighten it down a bit to preload the bov spring and ull be fine.
just an update.
the bolt is a metric M6.
car drives much better with the bolt back in.
thanks
platinum.
thanks
platinum.
