Lost HKS SSQV adjustment screw - Will any bolt work >>
i lost the adjustment screw on the back of the HKS SSQV bov on a couple hard runs this weekend. i guess i did not have the nut tightened down.
anyway, can i just use any bolt that fits the hole or is there something special with the stock one. anyone know the length and pitch of it? thanks platinum |
Re: Lost HKS SSQV adjustment screw - Will any bolt work >> (platinum00)
i think its an npt bolt... try 1.8th... but the bolt doesnt do shit... why do you think the new ones dont have it
Re: Lost HKS SSQV adjustment screw - Will any bolt work >> (wantboost)
i figured as much..
so i can run without it just fine. i figured i was leaking boost without the screw. platinum. |
oh wait... it will. lol.... fjust get a 1/8th npt bolt... or weld the hole up
hey my buddy has a ssqv HKS on his car and all of a sudden one day it got really quite and he started gettting surge... this is after he put in a different bolt(idk it had anyhting to do with it considering all thjat bolt does is tighten a spring to hold the valve closed while boositing) but it did and he got a stock dsm bov (2 g plastic cant crush) now and it leaks and he only runs 10 psi as opposed to 16psi https://honda-tech.com/forums/images/smilies/emsad.gif
Re: Lost HKS SSQV adjustment screw - Will any bolt work >> (R6E6I6D)
it only preloads the spring a few mm or maybe a pound or two... no real improvement when its a pull type valve
well if i get a bolt that is the same length, then it shoudl work the same as the stock one...
i thought she was running a little funny. platinum. |
any bolt'll work unless ur running like 20 psi than itll just force the bov open and lose boost
im going to be running around 24 -28 psi.
why would it force the bov open with a bolt in there. platinum. |
no i said that kinda weird, If ur running a good amount of boost which you are, your gunna wanna tighten that bolt down a little b/c the presure flowing in the IC pipes can be enough to force the bov open. Inturn causeing you a boost leak https://honda-tech.com/forums/images/smilies/emsad.gif Soo just tighten it down a bit to preload the bov spring and ull be fine.
oh sorry
thanks everyone peace platinum. |
just an update.
the bolt is a metric M6. car drives much better with the bolt back in. thanks platinum. |
