coolant temp problem
Old Nov 19, 2005 | 11:15 AM
typeRobtypeS's Avatar
Default coolant temp problem
lately ive been having a problem with my coolant temp. after i warm the car up to operating temp the gauge only reads to not even the half way point so it says its reading somewhat cool. although i know that it has to be wrong considering my setup is a gsr boosted at 10 psi. even when i hit full boost the gauge still doesnt even hit the halfway mark. i recently just changed the thermostat and it didnt fix the problem. i was thinking maybe the coolant temp sensor but not sure. anyone with any ideas? it would be greatly appreciated.
thanks
Rob
Old Nov 19, 2005 | 12:35 PM
KooK's Avatar
Mustang Sally
Default Re: coolant temp problem (typeRobtypeS)
This is where your gauge should be for operating temp I believe. Unless I have a colder thermostat. Either way, as long as the heater is blowing out nice hot air and your not overheating. Don't worry about it too much.
Old Nov 19, 2005 | 02:55 PM
7mile's Avatar
mine is also doing that
Old Nov 19, 2005 | 05:52 PM
94DOHCGsr's Avatar
Default Re: coolant temp problem (7mile)
If you have a GSR, the thermostat is only a 170 degree f. The half way point is 190 degrees f i believe. That is why it doesnt go half way.
Old Nov 19, 2005 | 10:26 PM
gsr dood's Avatar
Default Re: coolant temp problem (94DOHCGsr)
ur runninng leeeeean^
Old Nov 19, 2005 | 10:32 PM
Default Re: coolant temp problem (gsr dood)
yea that pic shows exactly where mine reaches during operating temp. and whats that about running lean?
Old Nov 19, 2005 | 10:37 PM
gsr dood's Avatar
ha look in the pic at his air/fuel ratio hes runniing lean
Old Nov 19, 2005 | 10:43 PM
isnt that just because hes at idle?
Old Nov 20, 2005 | 10:33 AM
KooK's Avatar
Mustang Sally
Haha, that A/F gauge is the gayest thing... Well, taillights, but those both came with the car. I'm goina be replacing it with an oil pressure gauge here soon, maybe put a wideband on also.
Old Nov 20, 2005 | 03:09 PM
ME=ADRIAN's Avatar
Default Re: coolant temp problem (KooK)
your thermostat could be stuck open maybe..
my gauge would barely move so i checked the thermostat and it was stuck open .
changed it and now it warms up right away
Old Nov 20, 2005 | 07:42 PM
Default Re: coolant temp problem (DRAPESTER)
well as i said before i replaced the thermostat. i highly doubt a brand new thermostat would stick open
Old Nov 20, 2005 | 08:02 PM
53JDMDC2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr dood &raquo;</TD></TR><TR><TD CLASS="quote">ur runninng leeeeean^ </TD></TR></TABLE>
that would make the car run hotttttt
djfob
Feb 16, 2018 05:27 PM
obuhmyuh
Mar 7, 2010 01:27 PM
Chuethou_b18c5
Mar 15, 2007 10:46 AM
superstud
Oct 14, 2004 12:44 PM
_Endless_
Mar 24, 2004 07:38 PM
