YIKES.. overfilled oil.. then raced
Old Mar 11, 2002 | 05:59 PM
illusion's Avatar
Default YIKES.. overfilled oil.. then raced
well anyways.. i did an oil change last wednesday. the h22a takes ~ 5 qts of oil. when i was done filling the 5 qts.. the dipstick still showed the oil level low. so i went and put another quart in. dumb move? after that the oil level was in between the two markers. so anyway, today i checked the dipstick to make sure everything was good.. the oil level is WAY ABOVE THE UPPER MARK. at least double the length of the distance between the two above.
tomorrow im gonna let out some oil. my concerns.. that wednesday night we went to the drag strip. and for the hour drive home i drove pretty spirited to say the least.
what damage could i have done? how would i go about diagnosing it?
Old Mar 11, 2002 | 08:30 PM
ILOVEGIRLS's Avatar
Default Re: YIKES.. overfilled oil.. then raced (illusion)
if its really bad, you will blow a BIG white cloud out of your exhaust.
Old Mar 12, 2002 | 10:21 AM
illusion's Avatar
Default Re: YIKES.. overfilled oil.. then raced (ILOVEGIRLS)
ok so i shouldnt be that worried then?
Old Mar 12, 2002 | 11:10 AM
Kamin's Avatar
No dont worry, just change your oil. and you DID wipe the dipstick and then redip it into the pan correct? cause if its as high as i think your saying youll smell the oil burning and youll be shooting smoke
Old Mar 12, 2002 | 11:12 AM
b18b98's Avatar
don't be worried..your fine. Just let out the extra oil.
Old Mar 12, 2002 | 06:43 PM
smokin rubber's Avatar
Default Re: YIKES.. overfilled oil.. then raced (b18b98)
drain the extra oil or you could blow a gasket, the oil system is presurized and the extra oil has to go somewhere.
Old Mar 12, 2002 | 09:04 PM
ahcjar103's Avatar
Default Re: YIKES.. overfilled oil.. then raced (smokin rubber)
just let it out and it should be fine.
you do know that you're supposed to measure oil level 5 mins after turning the car off right? not cold.
Old Mar 14, 2002 | 07:06 PM
StorminMatt's Avatar
The oil system is pressurized. But this only applies to the oil that is being pumped to the bearings. NOT to the oil in the oilpan. So nothing is going to blow. The only potential problem that could occur from overfilling is oil starvation due to foaming from agitiation of the oil by the spinning crank. But if it is only a little overfilled (ie a quart or less), this is probably not going to happen.
highwhey
Nov 11, 2010 05:53 AM
19integra94
Dec 26, 2008 01:51 PM
iGGY366
Honda Civic (2001 - 2005)
Dec 6, 2007 02:17 AM
Campee
16
May 20, 2003 05:33 PM
CM-R
May 28, 2002 07:49 AM
