Balancing the engine
Old Mar 11, 2002 | 03:53 PM
TeggerLS's Avatar
New User
Default Balancing the engine
Okay what is involved and how much should it cost? I have a B18B1 out of a 95 integra, fully disassembled. I want to put in forged rods and pistons. So if I bring all the parts to someone minus-the pistons, rods, & rings....what do you think it would cost to have them blueprint/balance the engine? I don't want to buy rods and pistons and then find out I need the next size up, I'll let them measure to ensureI get the right parts.
I would need the block re-honed, and probably have them assemble the shortblock. THNX L8R
Old Mar 11, 2002 | 04:36 PM
Plan B's Avatar
Default Re: Balancing the engine (TeggerLS)
$60- go buy a shop manual.
Just kidding, if you aren't modifing the crank or anything and using all uniform pistons and rods, you should be straight on the balance side. Honing the block is definetly a good idea, i assume that your cross-hatch is f-ed up. (for example my engine had 150k on it and i broke it down to replace some valves and then realized i had the most perfect cross hatch ever!, even after tons of NOS) So check that, if it's straight, just take it to a machine shop to have your pistons and rods assembled ~$20.00. Then put it back together your self. Otherwise, assembling the whole engine shouldn't be but like $2-300.00. So check around go talk to some machine shops.
Old Mar 11, 2002 | 04:47 PM
TeggerLS's Avatar
New User
Default Re: Balancing the engine (Plan B)
I have a haynes manual, but it's total crap gotta get a Helms. I can actually still see some of the stock cross-hatch But I'd rather be on the safe side and have it re-honed. I just got done dissasembling everything, onlything's left on the block are this black rectangular box(catch-can??) and the water pump. I just wanted to pull the crank and pistons out and really see what condition the cylinder walls were in
Now it's just a matter of ordering the right parts, measuring for the correct bearings and putting it together How much do bearings cost on average? Anyone know?
Old Mar 11, 2002 | 05:03 PM
CRX_VTEC's Avatar
Honda parts are already balanced from factory
Old Mar 11, 2002 | 05:40 PM
TeggerLS's Avatar
New User
Default Re: Balancing the engine (CRX_VTEC)
I'm sorry I forgot to say I'm building for boost. I will not be using the stock rods/pistons.
Old Mar 11, 2002 | 07:43 PM
Big Teggie's Avatar
Im in nj also, what machine shop is gonna be doin the work? Im trying to find a place to do some work for me, but dont know who does good work on hondas. Thanks
Old Mar 11, 2002 | 08:24 PM
TeggerLS's Avatar
New User
Default Re: Balancing the engine (Big Teggie)
Not sure yet, but I might use the guy my bodyshop uses. He's been building engine's for about 20yrs. And has a flow bench etc. We'll see though.
Old Mar 12, 2002 | 05:13 AM
virginia_dude's Avatar
He will need your assembled rods and pistons along with the crank to do the balancing. heavier or lighter Rod/piston assy requires adding/removing weights on the crank.
Old Mar 12, 2002 | 09:22 AM
b18b98's Avatar
when you find a place to do it please post prices because i'm planning on doing the same. thanks
lrayford
Mar 23, 2009 09:41 PM
boosted crx-r
Feb 21, 2007 08:41 PM
JDMjdawg
Jul 15, 2004 12:55 AM
geminis2k
Aug 13, 2002 05:04 PM
Trajic
Sep 5, 2001 08:28 AM
