need help with my rpm gauge
Old Nov 14, 2005 | 07:53 PM
myronwong's Avatar
Default need help with my rpm gauge
hi im having a problem with my cluster. my rpm gauge don't work. it was working fine the other day. must be something i did. what problems might it be or what should i check to see will it fix it. i have a 95 hatchback si
Old Nov 14, 2005 | 07:56 PM
o5mar1's Avatar
what did you do to the car latley, also check all your fuses under
Old Nov 14, 2005 | 08:03 PM
myronwong's Avatar
Default Re: (o5mar1)
well the mph guage works fine.
Old Nov 14, 2005 | 08:18 PM
o5mar1's Avatar
well its not a fuse than, ummmm check your connector if you have a friend with a 92-95 civic swap cluster and see if the rpm gauge works in there car it could be your cluster
Old Nov 14, 2005 | 09:13 PM
littleredcivic's Avatar
go to the pin on your cluster and test it for AC while the engine is running, the 12v ignition power for the tach gauge, and the ground for the gauge. a tach is a simple 3 input gauge. if everything is straight, then your gauge died.
xsicrx120
Sep 23, 2009 02:00 PM
spider2465
Jun 8, 2007 06:44 AM
asmallsol
Oct 11, 2003 11:34 PM
