When to reset the ECU...
Old Mar 11, 2002 | 11:03 AM
eerieCivic's Avatar
Default When to reset the ECU...
Sup everyone! I'm a newbie here - I've actually migrated from customcivics.com where I am a moderator.
Anyways, I've had an AEM short ram intake on my car for a few months now, but I recently heard that when installing an aftermarket intake it was a good idea to reset the ECU. I've heard of people doing this with a cool air intake, but is it necessary with the short ram? Thanks in advance!
Old Mar 11, 2002 | 11:05 AM
976's Avatar
976
New User
Default Re: When to reset the ECU... (eerieCivic)
I reset my ECU every mod, or every six months; which ever comes first!
Old Mar 11, 2002 | 01:09 PM
eerieCivic's Avatar
Default Re: When to reset the ECU... (w00t!)
Can anybody else confirm this?
Old Mar 11, 2002 | 02:55 PM
SlowB16's Avatar
Thats what I have heard. TO do this you just un-hook the battery correct? (- first)
Old Mar 11, 2002 | 03:32 PM
Katman's Avatar
haha jk..
you can reset the ecu if you go into the engine bay, and look for the fuse box on the passengerside shock tower. Look on the diagram for the ECU fuse. With the car off completely, take out the ECU fuse for about a minute, then put it back in...presto, reset ecu.
or you can undo the battery terminals and reset EVERYTHING in your car....radio settings too
its up to you..
Old Mar 11, 2002 | 06:41 PM
JMX's Avatar
JMX
Default Re: When to reset the ECU... (Katman)
am i not correst in thinking that that ECU corrects itself ..i.e. all the sensors which adjust and tune for max efficiency
Old Mar 11, 2002 | 09:34 PM
tinkerbell's Avatar
Default Re: When to reset the ECU... (jmx2323)
it is correct that you are not entirely correct.
t..
PS reset the ECU every time you get a code!!!!
Old Mar 11, 2002 | 09:36 PM
dirtySOHC's's Avatar
yes reset the ECU after all mods. it adjusts your car to the new goodie you got under the hood.
i thought everyone knew that though.
Old Mar 12, 2002 | 05:24 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: When to reset the ECU... (dirtySOHC's)
Resseting the ECU after a mod is pure BULLSHIT! The ECU will relearn itself. The ECU has set fuel/timing maps for WOT adjusted for IAT, MAP, and BAR. That is it!
Old Mar 12, 2002 | 07:13 AM
eerieCivic's Avatar
Default Re: When to reset the ECU... (Mista Bone)
I'm not a newbie...and I know how to reset the ECU, that's not what I was asking - I wanted to address this rumor that I heard that's all.
Old Mar 12, 2002 | 08:12 AM
SlowB16's Avatar
I have owned my car for about a year and a half now.Prior to yesterday I had never reset the ecu. I have installed a new fuel pump and an air filter since i bought it. I reset the ecu yesterday and the car runs so much better. Seriously it is night and day difference. No surging, smooth throttle all the way through......starts really fast. So dont tell me the ecu doesnt do anything. It helped me to do this. Seriously ressetting the thing has made more improvememnt on my car than anything else.
[Modified by SlowB16, 5:13 PM 3/12/2002]
Old Mar 12, 2002 | 11:12 AM
Katman's Avatar
Default Re: When to reset the ECU... (tinkerbell)
t..
lol
Old Mar 12, 2002 | 11:17 AM
owen_the_soyboy's Avatar
t..
Old Mar 12, 2002 | 02:15 PM
reVVin's Avatar
Default Re: When to reset the ECU... (owen_the_soyboy)
You don't necessarily HAVE to reset the ECU after adding a mod to your car. If you reset the ECU it will adjust itself right away to the new addtion to the car but if you don't, I am told that it will adjust itself over a 3 day period.
Old Mar 12, 2002 | 02:25 PM
tinkerbell's Avatar
Default Re: When to reset the ECU... (reVVin)
i *heard* the ECU can use GPS to track your car if it is stolen...
but that's on the OBD-VII ECUs
t..
DTC = reset ECU
tbuck23
Apr 1, 2007 05:50 PM
killa_lude
Jan 10, 2004 12:45 PM
mrmonk
Dec 5, 2003 12:17 PM
Fatty_1775
Aug 5, 2003 05:37 AM
Civic_Pilot
Feb 20, 2003 04:28 PM
