Car wont start
Old Nov 12, 2005 | 04:34 PM
del slw's Avatar
Default Car wont start
so i was on the dyno today. after the second pull, which was smooth as can be. i let the car idle 30sec and turned it off. after about 15min of letting cool down before the next pull, i went to start it again and it started but sounded like it had a bad miss. then it died. started again, and gave it gas but that did not help.
after numberous more tries it still would not start. it has spark, fuel, in time.
i did a compression test, and came away with not so very good numbers at all
85, 105, 115, 150
now i know that compression is horrible, but it should still be firing. and it's not.
it gets fuel for sure, cause each plug is wet. and the spark seems kinda dull orange. but i used a friends distributor and it still would not fire.
the ecu is ok. i did get 2 CEL's on the dyno, TPS and o2 heater. i cleared both of those, but still nothing. i'm at a loss here. i can deal with the low compression, as long as it still starts and is mobile.
any suggestions?
-Robbie
Old Nov 12, 2005 | 06:31 PM
nickromeo's Avatar
Default Re: Car wont start (del slw)
what fuel injectors are u using?
maybe one is stuck open.
happened to mee and it only ran on 3 cylinders and sounded like ****,
also maybe a leakdown test?
Old Nov 12, 2005 | 07:04 PM
del slw's Avatar
i have RC 750's
the car wont even fire on any cylinders, let alone start
Old Nov 12, 2005 | 07:14 PM
seen4ever's Avatar
Default Re: (del slw)
check all your grounds. check your timing belt, ensure that nothing jumped a tooth. but you need 4 things, timing, compression, spark and fuel. you have fuel, spark, weak compression.
Old Nov 12, 2005 | 07:57 PM
del slw's Avatar
i know. i checked the timing belt. it is perfect.
that's why i'm utterly stumped.
fuel
spark
compression(weak)
timing.
i have it all
it ran and idled fine on my 2nd pull. i changed nothing between that and the 3rd pull. and now that's where i'm at
TheHondaGuyDrew
Mar 23, 2018 01:48 AM
ORguy
10
Mar 22, 2011 05:25 PM
Bngo731
Jun 5, 2006 02:42 PM
white_98_gsr
21
Sep 2, 2005 05:01 PM
