idle question again.............
Old Nov 12, 2005 | 04:22 PM
b_serious's Avatar
Default idle question again.............
car has cold start problems.. i have a b18b i have to keep my foot on the gas in the morning until the car warms up or else it will die at idle... its the idle control valve correct?
Old Nov 12, 2005 | 04:33 PM
IVI's Avatar
IVI
Default Re: idle question again............. (b_serious)
could also be the fitv. fast idle thermo valve.
its directly below the throttle body, the backing has a plate thats removable, then theres a plastic piece inside that gets screwed back in.
i would also clean out the iacv.
Old Nov 12, 2005 | 04:58 PM
b_serious's Avatar
Default Re: idle question again............. (IVI)
mine doesnt have that.. i know what your talking about though.. there is nothing on the bottom of my t/b except two nipples with coolant hoses.. i cleaned out the idle control vavle 3 times already but no change
Old Nov 12, 2005 | 08:32 PM
b_serious's Avatar
bump
Old Nov 12, 2005 | 10:34 PM
Lord Helmet's Avatar
which year is the b18b? obd1 or obd2?
can't help you if we don't know the engine year, mods done, etc......blah blah blah.
Old Nov 13, 2005 | 01:03 AM
Boofster's Avatar
Default Re: idle question again............. (Lord Helmet)
For obd2, try unplugging the charcoal canister switch. Sometimes it gets clogged and messes with your vacuum at idle.
Old Nov 13, 2005 | 07:17 AM
KeithsDAteg's Avatar
dude I have had the same problem for years, Still havent figured it out!
Old Nov 14, 2005 | 05:23 PM
b_serious's Avatar
Default Re: idle question again............. (Boofster)
where's that at? and yes its odbII and its a stock swap no modds yet except intake and stage 2 clutch
Old Nov 14, 2005 | 07:13 PM
b_serious's Avatar
bump for the charcole thingy
Old Nov 14, 2005 | 08:09 PM
b_serious's Avatar
what is/wher is it? the canester thingy on the passenger side firewall?
Old Nov 15, 2005 | 03:05 AM
b_serious's Avatar
help =/
Old Nov 16, 2005 | 08:44 AM
b_serious's Avatar
anyone know?
Old Nov 16, 2005 | 09:01 AM
pny1981's Avatar
it could be your charcole canister. I have a 96 and remember that there was an emission recall on that year. When i got it serviced thats what they replaced. I had no problems at the time, and still dont. But it is worth looking into. i think it is on the pasanger firewall.
Old Nov 16, 2005 | 09:05 AM
xX-GSR-Xx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI &raquo;</TD></TR><TR><TD CLASS="quote">could also be the fitv. fast idle thermo valve.
i believe that G3's dont ahve a FITV for future reference. adn im having the same problem i think its the IACV but im kinda lazy to check it out. Mike.
**EDIT**dude check out team-integra.net for all ur integra needs.**
da9crxsi
Jun 4, 2012 09:52 AM
NayborhoodJohnny
Feb 8, 2011 07:44 PM
soodominican
Jan 16, 2009 09:32 AM
PWRDbyHseries
Oct 18, 2006 05:44 PM
