Would you help me about check engine light,SRS light,ABS light
I have a HOnda Accord 1995 EX ,Now the check engine light,SRS light,ABS light come on and i can"t turn off it .Would you help me the way to repair it and turn off it ,thank a alot
I don"t no ,when i start the car ,the check engine light and SRS light come on ,i can"t fight a problem on my car ,can"t you help me, THank
long..sorry.
do a search on the codes for the 5th gen accords. when you find that, you'll find the DIY oin how to check CEL codes.
you have to jump a plug thats located under the glove box (lil blue plug) w/a wire or paper clip..as long as you make a connection between the 2 terminals in the plug.
then you turn the ignition to the ACC. and count the # of tims the CEL light comes on.
the thing is, the light will blink fast or slow. if it blinks slow, it means 10. if it blinks fast, its a one.
so if it blinked say, 2 times slow and 5 times real fast.. 10+10+1+1+1+1+1 = 25
find out what CEL code 25 is and go from there.
i diagnosed a CEL code on my car this way and fixed the prob all from the help at H-T.
OR, you coudl just go to advanced auto and get them to check it out w/there fancy lil computer they have. the plug they will plug into is behind the coin tray directly beside the cigarrette lighter.
that might be the bast way since yoru throwing multiple codes.
hope that helps.
hope that helps.
thank you ,now I fixed the car ,but the cel and srs light can"t off ,would you help me to reset the memory of car ,thank a lot ,plese give me a picture if you can
make sure that all of the SRS sensors are plugged in.
Do with with the battery disconnected and wait about 10 mins before you start checking
here is a picture
sorry could not find the other image for the sensor locations.
here is a picture
yes unless the code is stored in nonvolitle memory (usually not the case with obd I cars)
if the light comes back on then it is an indication of a problem and your SRS will not function if you are in an accident. Usually it is a sensor that has failed but not always.....
stealth89hatch
Aug 15, 2005 04:48 PM
