Is this a problem??
Old Mar 10, 2002 | 07:06 PM
CHRIS 1.8's Avatar
Default Is this a problem??
My cylinder head gasket seems to be leaking. Do you think this will cause a problem on how my motor runs and operates? Or what should I do to stop the leakage?
Old Mar 10, 2002 | 07:08 PM
GokuSSJ4's Avatar
Default Re: Is this a problem?? (only JDM)
replace it !
Old Mar 10, 2002 | 07:17 PM
B_CRUZ!'s Avatar
i dunno much but that looks like a big problem to me.
Old Mar 10, 2002 | 07:19 PM
DragII's Avatar
25 Year Member
Default Re: Is this a problem?? (Spoon1)
I have bad eyes.....but if thats oil..you need to change it.
Old Mar 10, 2002 | 07:21 PM
CHRIS 1.8's Avatar
Default Re: Is this a problem?? (EvilDragII)
I already changed my oil.
Old Mar 10, 2002 | 08:13 PM
wantmorepower's Avatar
New User
Are you losing oil?
Old Mar 10, 2002 | 08:15 PM
CHRIS 1.8's Avatar
Default Re: Is this a problem?? (wantmorepower)
Eh...I don't think so...My block gets dirty though...
Old Mar 10, 2002 | 08:31 PM
memphiss13's Avatar
if you see it dripping down it is most likely the cam seal, not the head gasket, i have the same problem and one of my friends did too, just replace the cam seal and if thats not it then check out some other stuff before u go taking the head off.
Old Mar 10, 2002 | 08:36 PM
CHRIS 1.8's Avatar
Default Re: Is this a problem?? (rookie2nr)
Did you look at the pic? It has to be the head gasket because all the oil is on there...
Old Mar 10, 2002 | 09:43 PM
SPOON_BeIgHtEeNsEe's Avatar
hey did u fix that problem yet??? cause im having the same problem too...
Old Mar 10, 2002 | 09:45 PM
CHRIS 1.8's Avatar
Default Re: Is this a problem?? (SPOON_BeIgHtEeNsEe)
Nah man, not yet. I'm gonna take it to my mechanic tomorrow morning and see what he has to say. This crap is frustrating me!
Old Mar 10, 2002 | 10:56 PM
SlowB16's Avatar
It does not have to be the head gasket dude. The cam seal is right above there. I have the same problem. I think if your head gasket wa leaking your car wouldnt be allowing oil to get out while still being able to do its job. It is the cam seal. Or, possibly the distributor seal (I think that is the other seal in that area)....I would check the two I mentioned first before you go wasting alot of money..
Old Mar 11, 2002 | 03:31 AM
vntperformance's Avatar
Actually., i don't think it's ur head gasket, my car looked exactly like that, and all u have to do is change the cam seal, go with a STR w/O-Rings there the best...and problem solved.
vnt
Old Mar 11, 2002 | 03:36 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Is this a problem?? (vntperformance)
Okay, if you have a VTEC motor then I would almost guarantee that it is the VTEC oil pressure switch. I have seen dozens of those leak, and if it's not that then it could be the cam seal.
Could it still be the head gasket? Sure, but not likely. How about check all the way around the head, and if it's leaking in other places then you should be worried about the head gasket.
Try the VTEC solenoid and the cam seal - cheaper and easier. Always start with the simplest and cheapest **** first.
BTW: Sorry, but STR cam seals/plugs suck. I have seen nothing but trouble from them at the Honda/Acura shop that I work at. Good for you if they work for you, but 9 of the 10 I've seen were leaking. I would not trust an aftermarket company like STR (show pieces mostly) to seal up my Honda motor - genuine O.E Honda seals will be the best. Not trying to be a dick, but that's what I've seen.
Let us know dude.
Old Mar 11, 2002 | 03:52 AM
primoEF's Avatar
wash it off with brake cleaner and start the car, see where the oil is coming from, most of the time is from the top rather from the head gasket
Old Mar 11, 2002 | 05:11 AM
Trey's Avatar
25 Year Member
Default Re: Is this a problem?? (b18k1)
It's teh cam seal.....
I had the same problem with my B16a1 in the CRX.
The plastic gets old and hard and doesn't seal well and the oil leaks out. Just replace it with an OEM piece. $3 max.
Old Mar 11, 2002 | 06:38 AM
kenji's Avatar
25 Year Member
Default Re: Is this a problem?? (Trey)
A previous post mentioned a logical first step in determining where the oil leak is coming from by using brake clean and then running the motor.
There are three probable locations where the oil is coming from:
1. VTEC solenoid gasket - Not likely but it is possible. I have not seen one go bad in the last 10 years.
2. Cam seal - It is a possibility. It can be determined using the brake clean method described above. Honda redesigned the cam seal for the B-series motors a couple of years back. The newer ones use an o-ring.
3. Head gasket - I would put money on this one. I have seen dozens of Honda head gaskets leak oil from that corner. Especially on the 1G B16s. It has happened numerous times when people run a modified (thinner) Honda head gasket even with the use of copper spray.
I had a friend that had the same problem. He had the head and block resurfaced as well as replacing several head gaskets and the problem still persisted. Every possible solution to the problem was tried to no avail.
Good luck. I hope you fix it.
-kenji
Old Mar 11, 2002 | 07:00 AM
Thrashin's Avatar
, honda motors are famous for this problem
Old Mar 11, 2002 | 07:07 AM
92cxgsr's Avatar
WOW there seems to be a lot of things that could be wrong there. I think we need to have a honda technican come look at this.......
Old Mar 11, 2002 | 09:27 AM
CHRIS 1.8's Avatar
Default Re: Is this a problem?? (B18C5-EH2)
I just went to my mechanic and he cleaned all that dirt and grime ****. He told me to come back later in the day so it will be easier to spot a leak IF there is one...
01_civic
Classic Hondas
Jun 3, 2012 06:58 PM
preludeguy_92
May 23, 2005 06:39 PM
slowricer
Aug 14, 2004 08:34 AM
GreenMachineRex
Mar 15, 2004 01:47 PM
CHRIS 1.8
18
Mar 11, 2002 07:38 AM
