Are you running your "Nitrous" restrictor before the turbo, or out of the block?
Old Nov 9, 2005 | 06:49 PM
O16581724 5 2 5's Avatar
Default Are you running your "Nitrous" restrictor before the turbo, or out of the block?
Just curious where you put your's, i ran mine slightly bored out with a safty pin before the turbo and fed it too much oil causing it to ruin the seals. I bought a new one and put it in it's place, this stopped the smoking for awhile, then it started again, i moved it to the back of the block (before the oil feed) and it cut down on the smoke, but it started yet again. I put my bored out one in before the turbo and i think i didn't get enough oil to the turbo, 1,000 miles later, it got so much shaft play, it started hitting the turbine housing.
I'm wanting to buy a new turbo and i don't want to ruin another one, is it safe running an unbored restrictor out the back of the block into the feedline? How do i measure what size the feed is (as in 3an or 4am)?
Old Nov 9, 2005 | 10:32 PM
Default Re: Are you running your "Nitrous" restrictor before the turbo, or out of the block? (O16581724 5 2
Bump...
Old Nov 10, 2005 | 01:17 PM
Old Nov 10, 2005 | 01:38 PM
mrbsponge's Avatar
i use my oil restrictor (from ATP turbo) right on the turbo, its not a NOS jet but it is a restricter
Old Nov 10, 2005 | 01:46 PM
Default Re: (mrbsponge)
Mine's not a nitrous jet either, it's an Autometer part for their gauges. Thanks for your input.
Old Nov 10, 2005 | 10:08 PM
Default Re: (O16581724 5 2 5)
Bump for anyone running it out of the block...
Old Nov 11, 2005 | 10:13 AM
Buuuump...bump bump
Old Nov 11, 2005 | 10:23 AM
dpetro1's Avatar
what turbo are you using. i run a precision sc34 with a -3an feed line with no problems. no oil restrictor anywhere.
Old Nov 11, 2005 | 10:27 AM
Default Re: (dpetro1)
Garrett's T3, if i don't restrict it, it literally shoots oil out.
Old Nov 14, 2005 | 04:44 PM
b00st4life
Oct 22, 2014 11:25 AM
umair
Jul 22, 2010 06:25 AM
yellowturbo
Mar 7, 2003 10:36 PM
MikeMAN
Mar 4, 2003 04:35 AM
