have some noob questions on a deck plate
Old Nov 9, 2005 | 05:46 PM
4door's Avatar
Default have some noob questions on a deck plate
Hi,
I have a b18b block and I am considering to make it a 2.0 using a deckplate. But I have some concerns.
- can I use my stock crank?
- what length rods do I use? ( want to have a rod ratio of about a stock GSR if possible)
- what pistons?
- what timing belt
- what header can I use? off the shelf or custom?
I am keeping my non-vtec head(for now), is there an off the shelf header I can use that will clear the oil pan or will I have to go custom?
and what other concerns do I need to consider when using a deckplate to reach 2.0? or 2.x ?
its either this or a stock jdm b18c.
I posted earlier and someone mentioned LS/vtec but I don't think I'll be happy with that...
or does someone have links/websites on how I can calculate the lenght of the rods and stuff?
oh, and cost?
i'm thinking about 4-4.5k? woudl that be enough to build a 2.0 nonvtec? if not, what would my cost be (approx)
thanks.
Old Nov 9, 2005 | 05:57 PM
drdisco69's Avatar
Default Re: have some noob questions on a deck plate (4door)
So you're adding a deckplate to increase displacement, but you want to keep the same crank... Am I missing something? You can get to 2.0L by boring it, no deckplate required.
Old Nov 9, 2005 | 06:03 PM
4door's Avatar
Default Re: have some noob questions on a deck plate (drdisco69)
I really dont' know...
I guess I need a diff crank then.
what size is the b18b? 89mm? I thought it was a 92mm.
so I need a 92mm? what other engine is that out of? or is that aftermarket?
I was worried about rod ratio and strenght of boring it. I want to put turbo on it later, so I want it reliable.
Old Nov 9, 2005 | 06:33 PM
lohatch's Avatar
probably be easier for you to just get it sleeved. run 84x89, and you will be right around 2.0L. your R/S will be the same. and the LS crankshaft is 89mm
Old Nov 9, 2005 | 10:35 PM
4door's Avatar
Default Re: have some noob questions on a deck plate (lohatch)
I haven't thought about boring.
would aftermarket pistons have piston slap? or is that a myth/thing of the past?
also, what process is needed or how to you match the head to the new bore size?
thanks
EF9_TryMe
Aug 5, 2010 03:03 PM
nyceli
Mar 11, 2009 09:32 AM
done
Sep 30, 2004 04:53 PM
SoldMyEM1
Apr 16, 2004 04:42 PM
BlwnBlue
Dec 11, 2001 07:41 PM
