Who is an obd0 integra engine expert here?
Old Nov 8, 2005 | 08:51 PM
turbotime's Avatar
Default Who is an obd0 integra engine expert here?
Ok I have an obd0 (i think its obd0 right) 92-93 integra gsr engine (b17a1). I am trying to hookup an oilcatchcan but there is some mystery sensor in the port that is *supposed* to be used to evac. crankcase gasses in bseries engines.
WTF is this sensor???
https://honda-tech.com/zerothread?id=1428107
Old Nov 8, 2005 | 09:05 PM
mjc1055's Avatar
Default Re: Who is an obd0 integra engine expert here? (turbotime)
OBD1 started in 92, I believe. So that would make any GSR ever made stateside OBD1 at minimu.
Old Nov 8, 2005 | 09:07 PM
turbotime's Avatar
hmm, very weird, so the plot thickens...
NO ONE knows that sensor is? I am getting a closeup of the blakck sensor now, the green is the mystery plug..
Old Nov 8, 2005 | 09:12 PM
projectTeG's Avatar
the black ones the knock sensor. i believe the green one has to do with temp.
Old Nov 8, 2005 | 09:25 PM
turbotime's Avatar
black is 1 pin, green is 2 pin...
if green has to do with temp does that mean there is coolant flowing to that fitting?
Old Nov 8, 2005 | 09:47 PM
f2rider's Avatar
Default Re: (turbotime)
That looks like the sensor that acura told me was a "cold start sensor". I just helped with a b18a to b18b swap in a DA and we had to move it from the back of the block beside the oil pressure switch to the water neck. Hope that helps.
Old Nov 8, 2005 | 09:57 PM
turbotime's Avatar
so that sensor sees coolant? I read on the "Official PCV Thread" it can be used for crankcase blowby evac on ALL bseries engines.
Did they make ssome drastic design change to the water system or something?
Old Nov 9, 2005 | 07:38 AM
loudassVTEC's Avatar
I just looked up what the sensor was on the official honda/acura parts site.
It is the thermo sensor (a-108) part number 37773-PR4-A01
I have no idea what this does, but that's definitely the one.
This is a b17 block right. Cause I got the diagram for the 93 GSR motor, so this should be the one.
Old Nov 9, 2005 | 08:06 AM
turbotime's Avatar
yup its some type of thermo sensor. I think it has to do with oil since the sensor was covered in oil when i pulled it out...
Yeah its a b17 block. Wonder what the function of the sensor is? It seems like there wouldnt be that much solid oil that high up on the block, making it a weird place for an oil temp sensor...
Old Nov 9, 2005 | 08:28 AM
You'd be suprised to see how much oil comes out if you were to remove the breather chamber with the engine running! The bolt that held mine to the block vibrated loose, and came out, and I guess the pressure pushed the breather chamber off the block, so it was hanging by the hoses. I had just finished racing my friend, when we pulled up at the next red light, he saw oil dripping onto the road, so I pulled over to look, and the oil was dripping pretty steadily. It lost about a quart in the two miles it took to get back to my house! So theres plenty of oil that high up!
Old Nov 9, 2005 | 08:31 AM
turbotime's Avatar
ok cool i see, so thats why mounting the catchcan high up is key right? So oil drains back down and only the blowby makes it to the can right?
Old Nov 9, 2005 | 08:34 AM
Well with the stock breather chamber installed, all that should vent out is blow-by. The breather chamber actually separates the oil from the blowby, even though the blowby has oil in it, which is the purpose of your catch can.
Old Nov 9, 2005 | 08:54 AM
SwedBoy2999's Avatar
Since all 92-93 GS-R were equipped with A/C that temp switch is for the condenser fan. I would NOT use that port in the block to mount a catch can. That switch needs pressurized oil around it at all times so you need to plug it.
Old Nov 9, 2005 | 08:56 AM
turbotime's Avatar
and the a/c ran off oil temp? curious...
Old Nov 9, 2005 | 08:59 AM
Yes, and it is the fan that can run after the car is turned off. I've read the Cooling section of the helms manual like 50 times in the past two weeks trying to solve my own problem.
https://honda-tech.com/zerothread?id=1423339
Anyway, if you have any other questions, I know the cooling system pretty well right now.
Old Nov 9, 2005 | 09:51 AM
turbotime's Avatar
ok cool, great info. Ever solve your problem btw?
Old Nov 9, 2005 | 05:48 PM
Not yet, still waiting for the thermostat in the mail. I hope that fixes it. I've checked everything else.
Old Nov 10, 2005 | 10:44 PM
aussie-da's Avatar
that thing with the green connection is an oil pressure sending unit.. i broke a few in my DA before... if that not working u'll get a oil warning lights most of the time..
Old Nov 11, 2005 | 07:42 AM
projectTeG's Avatar
Default Re: (aussie-da)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aussie-da &raquo;</TD></TR><TR><TD CLASS="quote">that thing with the green connection is an oil pressure sending unit.. i broke a few in my DA before... if that not working u'll get a oil warning lights most of the time.. </TD></TR></TABLE>
i believe the oil pressure one is the one with the nipple connection.
Old Nov 11, 2005 | 07:51 AM
temp's Avatar
yes its to the oil sending unit, no you wont get oil warning lights, when i swapped the b18a into my CRX that thing was NEVER hooked up and i was running a PR4 ECU with no problems
Old Nov 15, 2005 | 04:24 PM
allhonda's Avatar
is obd1 wich started in 92. the sensor your talking about is the oil temp sensor, it activates the the radiators fans if the oil gets to hot. if you want you can jump the to wires with the gar running and you can see them come on. i didnt know hondas had COLD START SYSTEM!!!!!!!
Old Nov 15, 2005 | 04:29 PM
allhonda's Avatar
this is the sensor that makes your fans come on for no suppously for no reason when you get out of your car. when this happends check your cooling system cause this usually happends when the car overheats really bad
Old Nov 15, 2005 | 04:48 PM
Default Re: Who is an obd0 integra engine expert here? (allhonda)
It only controls the condenser fan, since the 92 GS-R has A/C.
018 37760-P00-004 SWITCH ASSY.(Controls the Rad. fan)
Both fans are controlled separately!
mario456
Apr 6, 2013 10:03 PM
DC_Legacy
Jun 3, 2008 06:13 AM
DC_Legacy
May 29, 2008 03:47 PM
T"u"Rtle
Feb 7, 2006 10:36 PM
SleeprCivic
Jun 18, 2003 07:46 PM
