DC header 4-1 or 4-2-1 ???
Old Mar 10, 2002 | 04:56 AM
jt-sport's Avatar
Default DC header 4-1 or 4-2-1 ???
my D16a pull up almost to 8000rpm (and still strong) even it using standart cams. On the dyno result ,the peak was at 6800 but the power still flat to 7800 (i think my Unichip ECU make it work that way)
Acording to my gear ratio calculation , i'll need the power arround 5000 - 8000 rpm.
Im confuse wich DC headder to buy , 4 into 1 or 4 into 2 into 1 ??
Regards
Odie Knownothing
Old Mar 11, 2002 | 11:07 AM
eerieCivic's Avatar
Default Re: DC header 4-1 or 4-2-1 ??? (jt-sport)
Get a 4-2-1 header for low end power and a 4-1 for top end power.
Old Mar 11, 2002 | 11:22 AM
SOHC_power's Avatar
Default Re: DC header 4-1 or 4-2-1 ??? (eerieCivic)
i would go with the 4-1 because when you are running your car, it pretty much stays in vtec. so when you are racing, low end power isn't going to help a whole lot. i wish i had gotten the 4-1.
Old Mar 11, 2002 | 11:23 AM
B19CivicHB's Avatar
Default Re: DC header 4-1 or 4-2-1 ??? (zvbxrpl)
ahh yes, but if it is a daily driver, how often are you above 6000 rpm? I like the 4-2-1 better because it seems to be more beneficial for me as a daily driver\occasional racer. Just me opinion.
-Nick-
Old Mar 11, 2002 | 11:43 AM
maggsgsr's Avatar
Default Re: DC header 4-1 or 4-2-1 ??? (B18CivicHB)
Yea 4-2-1 is for mid range,and the 4-1 high end.
Old Mar 11, 2002 | 01:38 PM
bps2799's Avatar
Default Re: DC header 4-1 or 4-2-1 ??? (maggsgsr)
Comptech's 4-2-1 made good power when compared to 4-1 headers in the Great Header Test.
Old Mar 11, 2002 | 06:31 PM
1996GSR's Avatar
Good point. That's why I got the 4-2-1. Yea, I'd love some more power in the VTEC range, but its not worth the decrease in midrange, and the fact my GSR is a daily driver, and frankly I would push the car past 6k rpms alot more with a 4-1 (which I'm trying to avoid doing all of the time b/c of high miles). Plus I figured my car could use a bit more mid range power.
Old Mar 12, 2002 | 05:20 AM
maggsgsr's Avatar
Default Re: DC header 4-1 or 4-2-1 ??? (1996GSR)
Thats why my comptech is on the way from auto salon,yea my dc 4-1 may have it by 1 hp at like 8k,but the comptech does better threw most of the rev range.
Old Mar 12, 2002 | 07:05 AM
jt-sport's Avatar
thanks for all of your oppinions
yeah ,but comptech need a lot more dollars then DC.
Now I think i'd better choose the 4-1 configuration, after i see the dyno chart between 4-1 vs 4-2-1 on DC's sites.
The 4-2-1 only strong below 4750, and it was only lil bit more from the 4-1.
and the 4-1 was give a very lot power above 4750.
And i only had one words in my head. And it was : "HORSEPOWER"
Thanks
Odie Knownothing
Old Mar 12, 2002 | 08:04 AM
maggsgsr's Avatar
Yea after research i found the dc 4-2-1 to be crap,the comptech gives hp threw almost the whole rev range.And it was tested on the ITR and produced the same power curves as the 4-1
[Modified by maggsgsr, 5:07 PM 3/12/2002]
Old Mar 12, 2002 | 08:45 AM
jt-sport's Avatar
eh... until now i cant find online shop for comptech producst. tell the sites please, and i forgot about the 4-2-1 comptech price
Old Mar 12, 2002 | 10:10 AM
maggsgsr's Avatar
go to http://www.comptechusa.com they have the tig welded header for 399$ and the mig for 499,both SS just different welds.Not very cheap but its a great header,maybe not the best but probobly the best USDM available.
[Modified by maggsgsr, 7:11 PM 3/12/2002]
Old Aug 26, 2003 | 03:57 PM
Eyewitness's Avatar
Theres nothing on there site about DOHC headers that i could find.....like for a b16a2
beastman@
Oct 23, 2007 12:02 AM
xelloss
14
Jul 14, 2006 01:18 PM
Fidelio25
Jul 27, 2004 10:15 AM
satoshi
Jun 29, 2004 06:49 PM
CaMiKaZi
Jun 14, 2003 05:23 PM
