side markers?
Old Nov 8, 2005 | 07:25 AM
spoonracer84eg's Avatar
Default side markers?
I just got a new pair of JDM fenders with side markers. I want them to do what the corner lights do. I have searched and there is not really any good advice. I just need to know how to wire them. I have 1 piece tyc headlights.
Old Nov 8, 2005 | 08:14 AM
JDM-EJ1's Avatar
Default Re: side markers? (spoonracer84eg)
What do you mean do what the corner lights do?
Old Nov 8, 2005 | 08:33 AM
JDM97EK's Avatar
Default Re: side markers? (JDM-EJ1)
I just got jdm fenders for my ek and after much searching i found that the side markers are actually side turn signals only. there is no way to hook them up to flash and stay on with the parking lights at the same time. (because the bulb only has one element). your oem corner light has three wires, hook the positive (forget what color) of the side marker to the green wire on your vehicle harness, and the black wire to the black on your harness. If you find a way for the lights to work both ways let us know.
Old Nov 8, 2005 | 08:39 AM
JDM-EJ1's Avatar
Default Re: side markers? (JDM97EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM97EK &raquo;</TD></TR><TR><TD CLASS="quote">I just got jdm fenders for my ek and after much searching i found that the side markers are actually side turn signals only. there is no way to hook them up to flash and stay on with the parking lights at the same time. (because the bulb only has one element). your oem corner light has three wires, hook the positive (forget what color) of the side marker to the green wire on your vehicle harness, and the black wire to the black on your harness. If you find a way for the lights to work both ways let us know. </TD></TR></TABLE>
Exactly. Either they are on all the time, or only on when your turn signal is engaged.
Old Nov 8, 2005 | 10:17 AM
duggy's Avatar
Can you swap out the single filament for a dual? I think then you could hook up all three wires to the side markers and have them stay on AND blink.
Old Nov 8, 2005 | 11:17 AM
Default Re: (duggy)
Well im about to go to the auto parts store. Im going to see if they have a "dual filament" with 3 wires. If not im going to get some things to do an inline splice and im going to have them stay on. If it comes down to that do you guys think they should stay on with parking lights or blink with turn signals??
Old Nov 8, 2005 | 12:09 PM
postman's Avatar
they are turn signal lights. should only come on when signal is on. alot cleaner that way to. you can have them when the corner are on though. use a multimeter and see what wire has volts or amps in it at the right time
Old Nov 8, 2005 | 12:18 PM
98coupe's Avatar
From: NOVA, but OC MD for the summers, 10th St., Tyson R.I.P, USA
Default Re: (spoonracer84eg)
http://forums.clubsi.com/showf...16908
Old Nov 8, 2005 | 12:20 PM
JDM-EJ1's Avatar
Default Re: side markers? (postman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by postman &raquo;</TD></TR><TR><TD CLASS="quote">they are turn signal lights. should only come on when signal is on. alot cleaner that way to. you can have them when the corner are on though. use a multimeter and see what wire has volts or amps in it at the right time</TD></TR></TABLE>
This the green wire, atleast on EGs. Tap your side marker wire into the green wire and your side markers will come on with your normal turn signals.
Old Nov 8, 2005 | 12:54 PM
Yep. You are correct. Checked it with a multimeter. The parts store didnt have a set up for a bulb with 2 filaments. So... I need to pick constant on or blinker.
Old Nov 9, 2005 | 08:21 AM
Got them wired up pretty easy. They only come on with blinkers. Look cool. Thanks for the help.
Old Nov 9, 2005 | 08:23 AM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonracer84eg &raquo;</TD></TR><TR><TD CLASS="quote">Got them wired up pretty easy. They only come on with blinkers. Look cool. Thanks for the help.</TD></TR></TABLE>
Glad we could help!
MugenManR
Oct 4, 2006 04:35 AM
lsvsol
12
Apr 23, 2006 05:37 AM
jes c
25
Sep 17, 2004 03:26 AM
crazyass05
17
Jun 17, 2004 06:49 PM
SKRacer
Dec 25, 2001 02:14 PM
