H22A distributor cap?? HELP!
Old Nov 7, 2005 | 04:59 PM
94ludeh22's Avatar
Default H22A distributor cap?? HELP!
I'm swaping my lude (h23) with a JDM H22A. The h23 is external coil and the JDM H22A came with an internal coil distributor. The H22A's dist. cap is cracked pretty bad but I cant find a replacement at any parts store. Does anyone know of an alternative cap that will fit? Or know if I use the H23 external coil on the H22, if it will work? If so, will it affect the performance?
Thanks
Old Nov 7, 2005 | 05:01 PM
Riptide101's Avatar
Default Re: H22A distributor cap?? HELP! (94ludeh22)
It should be a 90-93 honda accord 2.2 ltr distributor cap.
Old Nov 7, 2005 | 05:19 PM
94ludeh22's Avatar
Default Re: H22A distributor cap?? HELP! (Riptide101)
Tried it, the holes line up but it would be too far away fromt he rotor.
Old Nov 7, 2005 | 06:00 PM
MadCityLude
Guest
Posts: n/a
93 civic
Old Nov 7, 2005 | 06:06 PM
94ludeh22's Avatar
Default Re: H22A distributor cap?? HELP! (EuroR92Lude)
The 93 civic one, I think, will fit. Its the same part number as the 94-00 Integra non vtec. I think it will fit but the actual internal coil that extends into the distributor cap is broken. Im getting into almost just having to replace the whole distributor.
Old Nov 7, 2005 | 06:09 PM
MadCityLude
Guest
Posts: n/a
I got a dizzy for an H22 if you want to keep your car external coil
Modified by EuroR92Lude at 8:42 AM 11/8/2005
Old Nov 8, 2005 | 02:46 AM
BB4vTak's Avatar
i have a jdm h22 type s and used a 92-93 integra gsr dizz cap... the del sol vtec will work as well... yea you can use the h23 distributor on it and run external coil...
Old Nov 8, 2005 | 05:37 AM
MadCityLude
Guest
Posts: n/a
Yea the H23 dizzy wil work also!
Good Luck
Old Nov 8, 2005 | 06:17 AM
Gillard82's Avatar
its a accord cap, had the same problem
Old Nov 8, 2005 | 06:20 AM
MadCityLude
Guest
Posts: n/a
Default Re: H22A distributor cap?? HELP! (Gillard82)
I ALMOST guarantee it is Civic and Intergra not 100% on the exact years
94CDMeg
Aug 7, 2008 06:06 PM
LukieLuc
Aug 27, 2007 09:20 PM
fuckaBitch16
Mar 7, 2006 12:45 PM
markyh
Jul 6, 2005 05:58 AM
rick_spiff
May 14, 2003 05:34 PM
