please help.. my car wont start
Old Nov 7, 2005 | 03:33 PM
B18Cej1's Avatar
Default please help.. my car wont start
i got in my car last night and it wouldnt start. i thought it was the fuel pump because everything else seemed fine, it just wouldnt turn over. i replaced the fuel pump today and still no results. could it be anything else?
Old Nov 7, 2005 | 03:42 PM
B7AudiA4's Avatar
Default Re: please help.. my car wont start (B18Cej1)
spark plugs? does it sound like a dying sound? or does it not make anysound at all =X
Old Nov 7, 2005 | 03:48 PM
2.0L EK's Avatar
Default Re: please help.. my car wont start (FutureITR)
It doesnt turn over at all??
a couple things you can check...
Turn the car to the ON position and listen for the fuel pump to turn on
Check all fuses (under the hood - fuel pump, injector, etc...)
Check main relay (under dash on driverside)
How much gas is in the car
B18Cej1's Avatar
everything sounds normal, doesnt sound like its dying, it cranks just wont turn over. gas is half full and fuel pump makes noise when key is "on"
Old Nov 7, 2005 | 04:24 PM
B18Cej1's Avatar
any one else?
Old Nov 7, 2005 | 04:32 PM
AbitAvenger's Avatar
doesnt sound like main relay... ignition coil?
Old Nov 7, 2005 | 04:41 PM
B18Cej1's Avatar
Default Re: (AbitAvenger)
when i tried to relieve the pressure by loosening the nut on top of the fuel filter no gas came out so does that mean its my pressure regulator?
Old Nov 7, 2005 | 04:44 PM
johnwilly1000's Avatar
i got same prob with my honda 1999 sedan.its in the mechanics at the moment. ill let u know how it goes when it finished
Old Nov 7, 2005 | 07:22 PM
B18Cej1's Avatar
Default Re: (johnwilly1000)
bump
Old Nov 7, 2005 | 09:03 PM
B18Cej1's Avatar
Default Re: (B18Cej1)
Old Nov 7, 2005 | 09:11 PM
civic_driver's Avatar
if it wouldn't turn over it's ignition switch/battery/connection/starter issue and nothing to do with fuel system... if it turns over but doesn't start then it could be the fuel pump
try push starting it... if it starts and runs it's not your fuel pump for sure
Old Nov 7, 2005 | 11:32 PM
B18Cej1's Avatar
Default Re: (civic_driver)
oh i worded it wrong then.. its turning over but its not starting i tried push starting it last night and it didnt do anything. i was wondering if it couldve been the fuel pressure regulator since no gas was coming out of the banjo fitting under the hood when i loosened it(?).. any help or input is appreciated, its my daily driver and gets me to school and work.
Old Nov 8, 2005 | 05:05 AM
urname7698's Avatar
Do you hear the pump come on but still no pressure at the banjo bolt? You can check for flow by pulling off the return line after the FPR and attaching a small hose into a bucket.. remember the fuel pump only comes on for a few seconds if the car isn't running.
If there is no flow, I doubt its the FPR. Usually they just get stuck .. wouldn't stop flow completely.. you should have pressure at the fuel rail (or the banjo bolt at the fuel filter).. if not.. its either the pump or the lines from the pump to the fuel filter. Maybe your filter is completely plugged? Lastly.. check to make sure that you actually have gas in the tank.... maybe the sender is messed up.
Broke_not_built
Aug 22, 2011 10:40 AM
xjm92x
Mar 28, 2011 06:18 PM
Jooleeus
13
Jul 20, 2008 08:46 AM
ludecrasy87
Dec 10, 2006 09:07 PM
Seatown
Nov 14, 2006 06:51 AM
