Hybrid header question....
hey guys i was wondering if u could help me out.... im looking to buy a header for my b18c1 in my eg hatch, i've heard that i need a B16 99-00 CIVIC SI header, is this true? also wondering if i got say and dc sports jdm 4-1 header for a b16, would the header clear my oil pan on my b18???
thanks in advance guys..
The B16 Header will rub on your oil pan, it will not fit a B18C properly. I would buy a header to fit a USDM Type R Integra and it should bolt right up. A GSR header will work but there is not a bung for your O2 Sensor, since the GSR cat has the hole for the O2 Sensor. The JDM ITR header will work but it has a larger collector, 2.5", and you would need to modify your test pipe or cat to accept the larger collector. Good Luck!
vestalfootball72
Oct 26, 2006 10:34 AM
