Speedo doesnt work all the time Please help
Old Nov 6, 2005 | 05:54 PM
duneracer69's Avatar
Default Speedo doesnt work all the time Please help
my speedo on my on my 95 honda civic hatch back doesnt work all the time. I have replaced the cluster and the speed sensor and gear. Please help
Old Nov 6, 2005 | 05:57 PM
blkSi's Avatar
Default Re: Speedo doesnt work all the time Please help (duneracer69)
did you check the connection at the transmission?
Old Nov 6, 2005 | 05:58 PM
.Ry's Avatar
.Ry
Default Re: Speedo doesnt work all the time Please help (blkSi)
Make sure none of the running wires are frayed or exposed.
what connection not sure what you are talkin about
Old Nov 6, 2005 | 06:00 PM
ekcivic9's Avatar
the vss. or the vehicle speed sensor.
when i got my car i had the same issue, but i had to replace the cluster.
Old Nov 6, 2005 | 06:05 PM
blkSi's Avatar
not exactly sure what its called but when i had my '89 civic hatch my speedo wouldnt work and it was because the wire wasnt connected all the way to my transmission and i just needed to push it in more
Old Nov 6, 2005 | 06:37 PM
Default Re: (blkSi)
are you talkin about the wire for the speed sensor.
Old Nov 6, 2005 | 06:50 PM
.Ry's Avatar
.Ry
Default Re: (duneracer69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duneracer69 &raquo;</TD></TR><TR><TD CLASS="quote">are you talkin about the wire for the speed sensor.</TD></TR></TABLE> Yes he is, hopefully you checked it already. When mine started to flake out I had to replace the cluster. Its really common on hondas for the cluster and the vss to go bad. In that its possible the ones you bough were bad also. Take it to a shop and have the read the output signal on the VSS. If its strong move on. Buying something used doesnt always mean it will work.
foxdecoy
Aug 21, 2009 03:41 PM
EGed up from the seat up
34
Sep 16, 2008 06:37 AM
dudeomega2000
Jul 23, 2007 01:53 PM
hip_hop_s0ulchild
Mar 1, 2007 03:41 PM
snackpack
Dec 18, 2006 02:39 PM
