integra disc brake
You need the 99-00 civic Si cables, porportioning valve, and master cylinder.(I've heard that you might need to get the whole master cylinder/brake booster set up)
Everthing should be from an Si, even if you are using Integra rear disc brakes. However, I have heard that you will need to use Integra rear brake lines for Integra rear brakes.
Hope that helps!
I also have a 98 HB and am planning on doing the conversion ASAP as well.
Hope that helps!
Cap'N Chronic
Mar 27, 2022 07:16 AM
kirkland08
14
Mar 17, 2011 08:58 PM
Johnny Is Bored
10
Sep 19, 2008 01:33 PM
civcexcoupeblack
Dec 25, 2002 07:58 PM
