what kind of ecu ?
Old Nov 6, 2005 | 02:26 PM
slipage's Avatar
Default what kind of ecu ?
hello. i have a 94 civic ex with a b18c1 engine swap.
i was wondering what kind of ecu i should get. i was thinking about getting a p28 ecu, but my friend pointed out to me that it's an ecu for a civic, and not a gsr. would this still work? if not, what kind of ecu should i get ?
Old Nov 6, 2005 | 02:30 PM
eg6ajk's Avatar
Default Re: what kind of ecu ? (slipage)
if motor is stock use a P72 OBDI ECU. Otherwise chipped P28 with IAB hardware will do the same and might be slightly cheaper, only thing it will not have is knock sensor which is pretty usless.
Old Nov 6, 2005 | 06:24 PM
slipage's Avatar
what determines if the motor is stock (sorry, i'm really new to this car thing) .
Old Nov 6, 2005 | 06:25 PM
my_slow_civic's Avatar
Default Re: (slipage)
N<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slipage &raquo;</TD></TR><TR><TD CLASS="quote">what determines if the motor is stock (sorry, i'm really new to this car thing) . </TD></TR></TABLE>
Nothing done to it.
Old Nov 6, 2005 | 06:31 PM
slipage's Avatar
well yeah..
but does having intake / exhaust count ?
Old Nov 6, 2005 | 06:33 PM
slipage's Avatar
also, what does OBDI and IAB mean?
sorry i'm such a scrub =\
Old Nov 7, 2005 | 09:04 AM
slipage's Avatar
bump
Old Nov 7, 2005 | 09:14 AM
dpetro1's Avatar
when we say stock motor we usually mean internal things like pistons or headgaskets that change compression, or cams that will need to be tuned.
since it sounds like you are running a gsr swap with bolt-ons, then a p72 would be your best bet.
depending on the year of your car and motor, you will need either OBDI or OBDII
IABs refers to the secondary intake runners in your intake manifold, civics do not have this so a civic ecu will not know how to control them unless modified.
just use the p72 and you will be fine. kinda makes sense to use the ecu that would normally control that engine right?
Old Nov 7, 2005 | 10:08 AM
peacexisxfree's Avatar
Default Re: (dpetro1)
find out what year the gsr swap is. then youll know whether you need an obdI or obdII ecu.
Old Nov 7, 2005 | 06:43 PM
slipage's Avatar
thanks for the responses they really helped.
i went to one6 motorsports today, and i bought a skunk2 gsr intake manifold, a skunk2 chipped ecu (or something like that, also can't remember if it's OBDI or OBDII), and then i bought an apexi v-afc II . i'm so broke tho, i spent 850 dollars in one day, so yeah.
serrilion
May 16, 2011 03:23 PM
Lasky
Nov 9, 2007 11:29 AM
kartman
Apr 18, 2007 11:32 AM
robbizza
11
Sep 23, 2006 11:07 PM
bearboy80
20
Sep 17, 2003 02:20 PM
