header will it fit do i need a new gasket or can i use the same one
my little bro has a hatch with the motor d15b1 and i want to take the header off there and put it on this d16y8 well i need a new gasket or can i use the same one.... ohh and wil it fit... it looks like it will but not sure dont want to take anything off if it didnt work
Unless there is some little detail that i can't think of, it should fit. D-series to D-series. As for the gasket...I put a dc header on my Y8 and re-used the same gasket. I haven't had any problems.
are u sure? because if thats true dude im going out right now and changing that **** over ha ha my little bro is on vaction he is going to come back and he is not going to have a header im going to see if he can tell hahahahah
it should fit no problem, and if the gasket is in good shape i dont see why you cant use it again, i have used me exhaust manifold gasket probably like 10 times lol dont have a single leak
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">it should fit no problem, and if the gasket is in good shape i dont see why you cant use it again, i have used me exhaust manifold gasket probably like 10 times lol dont have a single leak</TD></TR></TABLE>
It depends on the condition of the gasket.... if it's all mangled and bent out of shape, kind of a no-brainer. But if it looks good and is still relatively pliable, re-use that mo-fro.
I haven't had any issues either.
nope it matched up perfect thanx for the help and i had a metal gasket so i just reused it the only trouble is now that my pipe that i put on his car wont match up if only i had 2 more inches of pipe lol well at least when he starts it up when he gets back from vaction he will know hah ahah straight headers on a litttle 10 15 kinda sounds like a biffy lawn motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WaltersCivic17 »</TD></TR><TR><TD CLASS="quote">nope it matched up perfect thanx for the help and i had a metal gasket so i just reused it the only trouble is now that my pipe that i put on his car wont match up if only i had 2 more inches of pipe lol well at least when he starts it up when he gets back from vaction he will know hah ahah straight headers on a litttle 10 15 kinda sounds like a biffy lawn motor</TD></TR></TABLE>
if his went onto yours fine, then yours should be the same going over to his. I don't see how two headers that are the same won't interchange.
If it's the connection point between the CAT and the Header than there is a chance he made need extra pipe or maybe just pull the exhaust forward a little bit. Even though he swapped with his brother, getting 2 inches of sway between the connection of your CAT and your Header isn't unreasonable. It could happen. He may need to just play with it a little more and pull it forward for it to bolt up properly.
newbie007
Sep 3, 2012 04:55 PM
