header will it fit do i need a new gasket or can i use the same one
my little bro has a hatch with the motor d15b1 and i want to take the header off there and put it on this d16y8 well i need a new gasket or can i use the same one.... ohh and wil it fit... it looks like it will but not sure dont want to take anything off if it didnt work
Re: header will it fit do i need a new gasket or can i use the same one (WaltersCivic17)
Unless there is some little detail that i can't think of, it should fit. D-series to D-series. As for the gasket...I put a dc header on my Y8 and re-used the same gasket. I haven't had any problems.
Re: header will it fit do i need a new gasket or can i use the same one (green00EX)
are u sure? because if thats true dude im going out right now and changing that **** over ha ha my little bro is on vaction he is going to come back and he is not going to have a header im going to see if he can tell hahahahah
it should fit no problem, and if the gasket is in good shape i dont see why you cant use it again, i have used me exhaust manifold gasket probably like 10 times lol dont have a single leak
Re: (92'BluV-tecHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">it should fit no problem, and if the gasket is in good shape i dont see why you cant use it again, i have used me exhaust manifold gasket probably like 10 times lol dont have a single leak</TD></TR></TABLE>
It depends on the condition of the gasket.... if it's all mangled and bent out of shape, kind of a no-brainer. But if it looks good and is still relatively pliable, re-use that mo-fro.
I haven't had any issues either.
Re: (mwieczorek43)
nope it matched up perfect thanx for the help and i had a metal gasket so i just reused it the only trouble is now that my pipe that i put on his car wont match up if only i had 2 more inches of pipe lol well at least when he starts it up when he gets back from vaction he will know hah ahah straight headers on a litttle 10 15 kinda sounds like a biffy lawn motor
Re: (WaltersCivic17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WaltersCivic17 »</TD></TR><TR><TD CLASS="quote">nope it matched up perfect thanx for the help and i had a metal gasket so i just reused it the only trouble is now that my pipe that i put on his car wont match up if only i had 2 more inches of pipe lol well at least when he starts it up when he gets back from vaction he will know hah ahah straight headers on a litttle 10 15 kinda sounds like a biffy lawn motor</TD></TR></TABLE>
if his went onto yours fine, then yours should be the same going over to his. I don't see how two headers that are the same won't interchange.
Re: (gftgrill)
If it's the connection point between the CAT and the Header than there is a chance he made need extra pipe or maybe just pull the exhaust forward a little bit. Even though he swapped with his brother, getting 2 inches of sway between the connection of your CAT and your Header isn't unreasonable. It could happen. He may need to just play with it a little more and pull it forward for it to bolt up properly.
newbie007
09-03-2012 04:55 PM
