Odd problems at WOT
1. When I'm at WOT, roughly around 4-5k, I'm hearing something like a grinding noise similar to that of a bad throw-out bearing in a manual tranny. When I hit VTEC, it's gone. I adjusted the valves last night and that didn't seem to fix the problem.
2. Also, when i'm at WOT for a while I'm smelling something like gas inside the car. Possible exhaust leak?
3. I get a huge puff of black smoke out the tail pipe when I step on the skinny pedal.
automatic mini-me
b7/z6
about 144k miles on block and head
usual i/h/e
ignition timing at 16* bdtc
using y7 cam gear
dented oil pan and bad oil leak from rear main
no cel.
automatic mini-me
b7/z6
usual i/h/e
using y7 cam gear
no cel.
MY plugs look normal. I'll take a picture of them later.
I'm running a stock z6 camshaft or so I hope.
the y7 cam gear is to correct the half tooth timing error with mini-me swaps.
I don't know where you got the idea of the torque converter going out. Please elaborate.
Hm.. I think my compression tester broke. I'm not getting a reading in any cylinder. I pulled all the plugs out and hooked up the the tester to a cylinder.
I checked the coolant level in the overflow and radiator and they seem a little low. Also if it helps any, my engine sucked up water but not a lot. Car seems to run fine though.
Anyhow, here are pictures of the plugs. They look normal to me.
Maybe it is pinging. I know I leave a big cloud of smoke behind me when i'm at WOT. I got me a new O2 sensor and will install it later.
Here are the compression readings:
1: 200
2: 210
3: 210
4: 210
Considering getting my ecu chipped at this point.
1: 200
2: 210
3: 210
4: 210
ur compression is great, don't worry about that. the plugs look ok, maybe that brown coloration means u could lean it out a very little but running a tad rich is a good thing and wouldn't make u have the problem u r having.
Import_spoon
17
Nov 12, 2009 04:22 AM
