Timing belt alignment problem...
Old Nov 4, 2005 | 10:17 PM
hackish's Avatar
Default Timing belt alignment problem...
Ok, I've built this B18A1 with crank, sleeves, pistons rods, adjustable cam gears etc. Whole nine yards. Started it up for a test this evening but it seems to have a timing belt issue.
The timing belt moves toward the head about 1/4" off the timing pulleys. I've built more than a couple of engines and I've never seen anything like this. Does anyone have any suggestions?
-Michael
Old Nov 4, 2005 | 11:13 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: Timing belt alignment problem... (hackish)
did you reinstall the 2 timing belt guides on the crank pully?
Old Nov 4, 2005 | 11:20 PM
Cuda70's Avatar
Default Re: Timing belt alignment problem... (PURPLETERROR aka BIGMATT)
Old Nov 5, 2005 | 06:53 AM
hackish's Avatar
Hrm. I'll double check that. I remember looking at the diagram and seeing only one little spring washer type affair in the shop manual. Is one supposed to go on the crank side? I don't remember these being larger than the pulley itself.
-Michael
Old Nov 5, 2005 | 10:01 AM
there are 2 washers , one goes on each side of the crank gear and keeps the belt from walking to either side
Old Nov 5, 2005 | 12:00 PM
shorto85's Avatar
Here you go... hope this helps...
Old Nov 5, 2005 | 08:00 PM
hackish's Avatar
Default Re: (shorto85)
Ho Hum...
Looks like I'll be taking a few things off an engine on Monday. Thanks shorto85. I looked up the diagram and the one I was looking at just didn't show the inside part. Lazy honda technical writers.
-Michael
Old Nov 7, 2005 | 09:16 AM
JimBlake's Avatar
Default Re: (hackish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hackish &raquo;</TD></TR><TR><TD CLASS="quote">... the one I was looking at just didn't show the inside part...</TD></TR></TABLE>If you were looking at a 1996+ drawing, the OBD-2 engines don't have the inner one. The crank sprocket has an extra flange that triggers the CKF sensor, & also makes the inner washer unnecessary.
Old Nov 15, 2006 | 04:54 PM
ari.'s Avatar
Default Re: (JimBlake)
aznflipboi08
Dec 27, 2009 11:24 PM
daylon1650
Feb 21, 2009 07:22 PM
Bob_760
Jan 30, 2008 02:48 PM
B18C-Hatch
Sep 5, 2006 07:52 PM
hitvtecgetloud09
Mar 21, 2004 05:27 PM
