my radiator hoses wont hook up to B16a2
Old Nov 3, 2005 | 06:21 AM
streetracerof06's Avatar
Default my radiator hoses wont hook up to B16a2
ive got a b16a2 swap but the hoses off my stock engine are to small for the b16 and the b16 hoses are a little to big for the stock radiator. Ill be calling O'rileys today to see if they make a reducer from one hose to the other but any other ideas would be great. thanks in advance.
Old Nov 3, 2005 | 06:59 AM
dohcdelsol93's Avatar
Default Re: my radiator hoses wont hook up to B16a2 (streetracerof06)
I used a 94 del sol DOHC VTEC upper hose for my swap, had to use 2 hose clamps on the radiator side because the dohc hoses are larger than the nipple on the radiator, I usually apply a bit of gasket sealer around the fitting before sliding the hose on for added security. As for the lower hose I used the stk sohc radiator hose, my bottom end is off of an ls so my lower hose may be different. But the top will definatly work, i have a b16 head.
Old Nov 4, 2005 | 04:43 PM
Mr. JDM-GSR's Avatar
how about a gsr in a 1997 civic ex
Old Nov 4, 2005 | 05:00 PM
civic97dx's Avatar
Default Re: (Mr. JDM-GSR)
ok, you guys have three options:
1) buy a reducer and use the B-series hoses(I run gsr hoses in my ek w/gsr swap)
2) buy a radiator for a b-series civic (delsol or 99-00 si), you can also call a radiator shop and have one made. this is what I did.
3) be getto and use hose clamps to clamp the **** out of the B-series hoses on the d-series radiator. I did this at first and it will leak over time.
I recommend you buy a radiator which can keep up with the needs of the engine, there is a reason why the d-series rad. is smaller.
Old Nov 5, 2005 | 04:11 AM
Default Re: (civic97dx)
I have a stk sohc vtec radiator in my 93 sol running an ls/vtec and Si tranny. I have a huge evo front mount IC and have never had over heating problems. I'm located in South Carolina so I may have problems running in Fla during hot summer days but even on 90 + deg days here, she runs right at 170 deg.
Old Nov 5, 2005 | 08:36 AM
i heard witht the gsr in a ek that you are to use the del sol dohc lower radiator hose withe the gsr upper with the stock radiator. is this true?
Old Nov 5, 2005 | 06:07 PM
b18tegg's Avatar
nm i didnt read right
Old Nov 5, 2005 | 06:08 PM
dohcMONSTER's Avatar
GSR DA radiator hoses
Old Nov 5, 2005 | 11:21 PM
transpar_nt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic97dx &raquo;</TD></TR><TR><TD CLASS="quote">ok, you guys have three options:
I recommend you buy a radiator which can keep up with the needs of the engine, there is a reason why the d-series rad. is smaller. </TD></TR></TABLE>
Option 4:
Use your stock hoses. Heat the end of the hose a little and lube the part of the rad that it attaches to. Many people on here have done it with no problems. And BTW, the D series rad is completely reliable to over 200whp. I researched the **** out of this for my swap. (I'll be getting a dual core rad when I go FI, but will keep the D rad until then.)
dcraige
Jun 24, 2010 07:43 PM
streetracerof06
Feb 13, 2006 01:14 PM
spoonek4
Jan 12, 2006 11:41 PM
hybridevul
Jun 16, 2005 07:03 AM
goforbroke
Jan 21, 2003 07:59 AM
