Y7 radiator hose problem with GSR rad
As topic. I have a GSR radiator for my 92 EH Civic with 99 D16Y7. What kinda hose would I need to hook up the rad and my block? Would there be any difference if I use the same GSR radiator setup on a 99-00 Civic?
Tried to search but can't find anything. Any help would be appreciated.
Re: Y7 radiator hose problem with GSR rad (spoonek4)
Can I just use rad hoses that are off from GSRs? Will the "bends" on the GSR hoses work on the D16Y7 block?
Looking at my y7 compared to the b16 swap i have in my garage. It looks like the bends and hoses are different on the B. The hoses are allso a bit bigger due to the bigger neck on the B-series radiator. I do not know if it will fit or not though. I'm using the Rad/hoses from the B16 with my b16 swap to be safe.
Re: (Ax3l)
Get 99-00 civic si hoses and ask for radiator hose adapters. They allow a bigger hose to fit on a smaller fitting. That way the SI hoses will fit on the radiator since they are the same size, and the adapters will allow the SI hoses to fit leak free on the engine.
streetracerof06
02-13-2006 01:14 PM
streetracerof06
11-05-2005 11:21 PM
