piston to deck hieght?
Old Nov 3, 2005 | 06:17 AM
Honda Crx's Avatar
Default piston to deck hieght?
i need to change deck to piston hieght to oem zc.? i need to change it to drop my compression. i have a d16z6 with pm7 pistons goinng in
Modified by Honda Crx at 8:01 AM 11/3/2005
Old Nov 3, 2005 | 07:01 AM
Honda Crx's Avatar
Default Re: piston to deck hieght? (Honda Crx)
top
Old Nov 3, 2005 | 08:51 AM
shamoo's Avatar
Will you make something up for me please?
So what are you asking? Can you throw in a thicker head gasket?
EDIT: I just saw your other thread. Piston to deck height is basically the distance from the piston at TDC to the top of the "deck" or block. Compression ratio is basically measured using this as a reference...kinda. The volume of the combustion chamber while the piston is at BDC versus the volume while the piston is at TDC. The closer it is to the "deck", then the compression will be higher.
H-allmotorda9
Feb 5, 2010 02:42 PM
vinuneuro
Jul 30, 2005 10:51 PM
Seraph0
Jan 10, 2004 05:40 PM
Sonny
Apr 26, 2002 08:24 AM
HX_Guy
Nov 8, 2001 09:03 AM
