Ultra Start Alarm help
Old Nov 1, 2005 | 09:52 PM
nocturnaldragon's Avatar
Default Ultra Start Alarm help
I have an Ultra Start 4500m alarm/remote starter. I like the alarm and haven't had any real problems with it other then one annoyance. In order to activate the remote start function you have to leave the car running hit the brake twice, exit the car, do the hoke poke and once you turn yourself around, arm the alarm, then and only then will the remote start work. Maybe
My question is am I better off **** canning the unit and getting something else that's made for an auto so I don't have to go thro this **** or can I mod this so it will act like an auto and I don't have to go thro this ****?
I have a safety switch idea I can set up on the shifter so the car will only work in the neutral position so it wont be unsafe.
Old Nov 1, 2005 | 10:08 PM
suspendedHatch's Avatar
Default Re: Ultra Start Alarm help (nocturnaldragon)
You're on the wrong forum. Theres a few people that can help you in the audio/security forum.
Old Nov 1, 2005 | 10:09 PM
Default Re: Ultra Start Alarm help (suspendedHatch)
Im posting in both, just on the chance I might get a hit here, I figure theres some users like me who never look at those forums who might know the answer.
Old Nov 1, 2005 | 10:20 PM
Carbonciv's Avatar
Get the Viper 791, 500 bucks but well worth every penny.
Old Nov 2, 2005 | 08:06 AM
Default Re: Ultra Start Alarm help (Carbonciv)
Morning Bump, I need to get this taken care of soon guys because winter is coming, I saw a no name brand one on ebay that will work pretty well too for 180. Im welcome to new sagestions for the alarm as well.
Old Nov 2, 2005 | 09:19 AM
515blue2kSi's Avatar
I installed a remote start on my Civic that was meant for an auto. It works great. Just use the ground while remote starting lead to bypass your clutch switch. If you want to make it safe from starting in gear then go to radio shack and get a magnetic reed switch. Make a bracket that holds the switch about a 1/4 inch from the bottom of your shifter balance weights. Then attach the magnet to the shifter weights. You will have to move the backet a few times to get it just right. With a little trial and error you should be able to make it so it wont start in gear. Just split off the hood pin wire, which is a ground. Run it to the switch and if its in gear it wont start because it thinks the hood is open.
Old Nov 2, 2005 | 09:39 AM
96CivicBoostCoupe's Avatar
Default Re: (515blue2kSi)
get any alarm/RS from DEI. IE viper, clifford, python, rattler, sidewinder, valet.... you wont regret it, in life you always get what you pay for..
Old Nov 2, 2005 | 04:04 PM
Thats basicly what I was going to use, a mercury switch is what I remember calling them tho. You attach the starter wire after the relay tho its pretty simple, then no need to add anther wire that you dont need.
Old Nov 3, 2005 | 05:04 PM
Come on guys, why is it no one ever responds to my posts?
Is it I'm asking to hard of questions all the time or do you people just not care
Old Nov 3, 2005 | 05:05 PM
Re reading your post gave me an idea, Good work
Old Nov 4, 2005 | 09:03 AM
Default Re: (nocturnaldragon)
Autopage RS855 is a better value than Viper 791XV. It's a few hundred cheaper, yet the same in every respect except for the lack of code hopping.
Old Nov 4, 2005 | 08:08 PM
Default Re: (suspendedHatch)
Thanks for the input
I'd like to keep the one in my car if at all possible, but am open to idea's for a replacement.
Old Nov 5, 2005 | 07:22 PM
Old Nov 5, 2005 | 07:27 PM
jdmpsicivic's Avatar
stick with anything from directed electronics, autopage stuff kinda sucks, works when it wants to, ive been installing for 6 years best like with dei, viper clifford etc etc.
Old Nov 6, 2005 | 09:02 AM
Ok since no one seems to have the info I need, Im looking at new alarms. I found this one on ebay but I know its an off name brand, does anyone know of a name brand company that carries this one with the same features?
The features I want the most are the 2-way remote, and the owner reconition would be nice, the 1mile+ range is a must tho.
http://cgi.ebay.com/ebaymotors...%3AIT
Old Nov 6, 2005 | 10:30 AM
did you search on the12volt.com for your alarm manual?
Old Nov 6, 2005 | 02:42 PM
That wont tell me how to make it for an auto, the one I have is either made for an auto or an manual there isent a switch that Im aware of.
Old Nov 6, 2005 | 10:04 PM
Carbonciv's Avatar
If you want range go with a CompuStar but the instructions kinda suck on installing them, I foud the all DEI products are good. Autopage is kinda like a german car, its fun for a week then it breaks. If you can get a Avan Gaurd 5, I know the spelled that wrong but whatever its a DEI product.
quicksilver1689
Audio / Security / Video
18
Sep 3, 2007 05:21 PM
nocturnaldragon
Nov 7, 2005 12:11 PM
aquarius
Jul 15, 2004 07:53 AM
mnskateboarder
Jan 26, 2004 04:11 PM
stock97
Dec 18, 2003 11:12 AM
