what does every use to lift?
Old Nov 1, 2005 | 06:51 PM
rewerbcrx's Avatar
Default what does everyone use to lift?
what does everyone use to lift the engine outta the bay... (what points i mean) are you guys wrapping around the engine? or is there crane points/lifting points that i didn't notice?
thanks
Old Nov 1, 2005 | 06:57 PM
rewerbcrx's Avatar
Default Re: what does everyone use to lift? (rewerbcrx)
vroom vrrrooomm vvvvvvvrrrrroooooommmmm
Old Nov 1, 2005 | 07:00 PM
CRXBart's Avatar
Default Re: what does every use to lift? (rewerbcrx)
Don't lift it, drop it. Dropping out the bottom is way easier. It's the only way I do swaps any more. Disassemble suspension, remove front x-member, remove all wiring hoses, cables, shift linkage, ect. drop the car on the ground with a creeper, or specialized rolling cart under motor. Remove motor mounts and lift car back up, roll motor out.
Old Nov 1, 2005 | 07:33 PM
rewerbcrx's Avatar
Default Re: what does every use to lift? (CRXBart)
CRXbart... that is a good idea but way past that point lol and none of those things needed to do such a thing... anyone else please
Old Nov 1, 2005 | 07:39 PM
RicedREX's Avatar
I dunno if if your asking how to lift a motor out ot where...but the motor mount brackets are a good place to chain up an engine lift...you can probably rent an engine lift at a hardware store if you do not have one.
Old Nov 1, 2005 | 07:48 PM
jisu009's Avatar
Default Re: (RicedREX)
Just buy a lift. They are like $100 at Schucks.
Old Nov 1, 2005 | 08:00 PM
CRXBart's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewerbcrx &raquo;</TD></TR><TR><TD CLASS="quote">CRXbart... that is a good idea but way past that point lol and none of those things needed to do such a thing... anyone else please</TD></TR></TABLE>
What do you mean none of that is needed. The only extra thing is removed is the xmember. You don't need a lift you can do it all with a jack and some jack stands.
Old Nov 1, 2005 | 08:29 PM
rewerbcrx's Avatar
its funny when i don't say something retarded i have to bump to get a response but its when i do say something dumb its like seabiscuit all over the thread ... either way the coming up sounds better than going down lol hahhaa ... i was confused but the haze is gone . i will try that... and for the lifting i have a lift, a very nice one, i was curious of the lift points on the engine or wrap it and lift. but thanks (the motor mount don't seem like a wise choice because the engine will flip flop on ya , or at least it seems that way.
thanks again
Old Nov 1, 2005 | 08:52 PM
91civicEX's Avatar
i use 1 bolt hole on the timing belt side of the intake manifold (there is a blank hole w threads) and one directly opposite it on the head. also 2 transmission bolts.
works on b and d series
Old Nov 1, 2005 | 09:03 PM
rewerbcrx's Avatar
Default Re: what does every use to lift? (91civicEX)
NICE thats what i was looking for THANKS
Old Nov 1, 2005 | 10:21 PM
HiProfile's Avatar
I use the 'blank' hole between the timing belt and intake manifold (I always take it off) and...a dizzy bolt. I'd recomend a tranny bolt instead, but use a longer bolt or a plate you can hook to.
I've done both ways up & down removal, and IMO they both have their strengths & weaknesses. In a perfect world I'd use a ceiling-mounted puller to lower the motor. It's easier to install/remove a motor from below if there's AC/PS/etc or a cramped bay like an EF. Installing from above also makes it hard to line up due to it angling in.
jaymua
Jan 31, 2009 08:51 PM
LukieLuc
Apr 12, 2007 11:49 AM
Lost_clearance
May 29, 2006 06:41 PM
KL14
42
Dec 9, 2005 04:28 PM
metal-x
Oct 22, 2002 10:48 AM
