LCA problem on EK with JDM ITR 5 lug
Old Nov 1, 2005 | 11:59 AM
EKtypeRhaTcH's Avatar
Default LCA problem on EK with JDM ITR 5 lug
I recently installed my JDM ITR 5 lug on my ek with JDM itr 16'rims (205-45-16). My rear tires stick out hella like it gives it crazy negative camber yet the top of the wheels rubs on the rear fender. Ive search about type r lca's on an EK and everyone said its too short. Since i have the itr 5 lug will the type r rear LCA's fit and fix my problem???
Old Nov 1, 2005 | 12:14 PM
someones got to know!
Old Nov 1, 2005 | 12:16 PM
SamB16's Avatar
yeah, same problem here..... don't forget the ITR pushes out the wheels by 5mm, reason you are rubbing is simply beacuase the car is too low. Either raise the car or have the fenders rolled.
Old Nov 1, 2005 | 12:20 PM
thanks for the input, i raised the car alread to prevent rubbing on the new tires, but i just dont like how the wheels stick out soo much, anyone know about the lcas?
Old Nov 1, 2005 | 05:10 PM
slowpokecivic's Avatar
Default Re: (EKtypeRhaTcH)
we can trade rims....my usdm itr dont stick out....lol jp...bump for a solution...
Old Nov 1, 2005 | 05:41 PM
hahaha i have those too however, bumpers for me!
Old Nov 1, 2005 | 11:07 PM
up for an answer before i go and get them
Old Nov 1, 2005 | 11:13 PM
JDMlyfestyle's Avatar
could have gotten some slightly bent trailing arm
compwc18's Avatar
You could use your stock suspsension and your stock LCA's and that could maybe fix the problem... Im not too sure, but when I put the 5 Lug on one of my EG Coupes, the rims didnt stick out and i used my stock civic LCAs....
Old Nov 1, 2005 | 11:15 PM
compwc18's Avatar
Default Re: (JDMlyfestyle)
JDMlyfestyle is right, you couldve gotten a bent trailing arm, but when you have a bent trailing arm sometimes all the bolts wont line up at all, I had to swap trailing arms on my 5 lug setup I had due to the fact that the arms was bent real bad.... You can just take the spindle off the trailling arm and swap it to your stock civic arm... I believe.... Please correct me if I am wrong...
Old Nov 1, 2005 | 11:58 PM
well i got the 5 lug from my friends shop and said it wasn't bent, looks fine on both sides with the 15" rims but once i put on the 16's i ran into this problem.
Old Nov 2, 2005 | 12:12 AM
CivicSiRX's Avatar
ur suppose to reuse ur ek lcas, as the itr/eg lcas have same dimension and differs from those from an ek.
so if you want a set of ek lcas that has holes for the rear sway bar, either u get a set of 99-00 Si lcas or aftermarket ek lcas.
Old Nov 2, 2005 | 12:21 AM
marshun's Avatar
Default Re: (CivicSiRX)
arent the lca's between the type r and the ek the same length?
i've got the 5 lug on mine and im using the ek rear lca's just cause my set didnt come with ctr lca's. i dont have any problems
Old Nov 2, 2005 | 12:47 AM
i think the dc ones are shorter, do yo have pics of your wheels? what size tires and rims are you running?
Old Nov 2, 2005 | 01:08 AM
the ek lcas are longer then the eg/dc lcas...i know because when installing the 5-lug onto my ek...the wheels kinda tucked in, so i had to basically re-use my stock lca's...
Old Nov 2, 2005 | 01:19 PM
marshun's Avatar
Default Re: (SLoWpOkECiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLoWpOkECiViC &raquo;</TD></TR><TR><TD CLASS="quote">the ek lcas are longer then the eg/dc lcas...i know because when installing the 5-lug onto my ek...the wheels kinda tucked in, so i had to basically re-use my stock lca's...</TD></TR></TABLE>
idunno, i had'em both by eachother, i didnt measure'em. but they looked to be the same length. i just sold'em to some show car guy for 160.
Old Nov 2, 2005 | 05:15 PM
CivicSiRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSiRX &raquo;</TD></TR><TR><TD CLASS="quote">ur suppose to reuse ur ek lcas, as the itr/eg lcas have same dimension and differs from those from an ek.
so if you want a set of ek lcas that has holes for the rear sway bar, either u get a set of 99-00 Si lcas or aftermarket ek lcas.</TD></TR></TABLE>
tesh
Jan 27, 2008 01:24 AM
JDM honey
Oct 4, 2007 08:59 AM
jime64871
Apr 16, 2006 03:07 PM
LHC
Jun 8, 2004 10:10 PM
Lynx
12
Jul 19, 2003 08:42 PM
